I’ve installed a Thinkware F750 (same wiring as F770 and F800) which requires a switched 12v wire (for activating parking mode) in addition to a constant 12v power source. Figured i will share some pictures for anyone who’s interested.
I’ve tapped into the 12v battery in the frunk with direct connection, and a red wire located in the front passenger footwell area for the switched 12v source. Since the wiring cable already included a fuse for both the constant 12v and switched 12v wire, no additional fuse connection is required.
Here are some pictures attached.
The yellow wire (labeled BATT) connects directly to the positive lead of the battery. And the black wire (labeled GND) connects to the negative lead of the battery.
Pry open the rubber sealing, fished the wire next to the edge of the rubber from the frunk into the front passenger footwell area.
Another shot of the rubber sealing from inside the car, in the front passenger footwell area.
For tapping into the switched 12v source from the front passenger area, I used Posi Tap which I think it’s a bit easier to work with and less intrusive to the original wire. (
https://www.amazon.com/dp/B00CMC5DII/ref=cm_sw_r_cp_api_8E-FAbKZ5SN4J)
