Note: This feature currently requires accessing the site using the built-in Safari browser.
So i was driving today and noticed that there was a difference in wh/km between the odometer and the energy chart. Any reason for this?
No, it's not a rounding error.Rounding error. I’ve checked a few times, and they match.
They are measuring different periods of use. Notice how the one on the left is "Since 03:53PM", and the one in the energy graph on the right is showing the average during the past 50 km of distance? Those are not the same time periods.
Usually i am at 130wh/km. There was a bit of traffic on the highway so the car was doing between 80 and 100kmph. Usually i do autopilot at 110 and get 130wh/kmWOW, 103. Best I've gotten so far is 141, but that is better than my 17' Volt at 181.
As I originally stated, I've tested it several times, the two figures will be close enough to be a rounding error, whatever you want to call it, it's within the margin of error, due to the rounded increments of measure, time or distance. Why do people like to make simple things hard? There's no practical difference between 98 and 103Wh/km
SR+?
I’m similar with ~130-140 Wh/km with AP set at 110-115 km/h.
I have some hills though. I guess bad traffic is good for something, eh? [obligatory “eh” required by international Gen-eh-va convention when conversing with fellow Canadians]
Yes SR+
Drive today to work was similar. A consistent difference of 250WH over 50 kms.
Oh, and the trip meter ticks up when the underlying number rounds up to 50.0, so you’re actual distance at that point is 49.95 km. Who knows how the “last 50” is updated and if it’s 100% up to date every second or not.
I don't believe this is accurate...Are you suggesting that my trip meter is going to say I have traveled 0.1 miles after only 0.05 miles?
I think the difference is that the consumption meter isnt as real time as you think. Its probably a km behind or so.
Yes. Try it. Drive 0.1 miles one way, then turn around and go back til you get to 0.2 miles.
0.1 = 0.05, 0.2 = 0.15, ... subject to delays in updating if any.
Everything on the display is rounded. Underlying the trip meter, the odometer is actually ticking off in meters. You can see the odo reading in miles in the API has something crazy like 6 decimal places![]()
