And have the car broken into. Thanks, but no thanks. Typically my trips are 7-14 days.lol - If its so close of a trip....lay your stuff down on the back seat.
No, other than what the car might do automatically.Is it possible to disable the engine in front with dual motors?
I like rear wheel driving from time to time.
Can't do that since I throw all my fast food trash there.lol - If its so close of a trip....lay your stuff down on the back seat.
Well, yes. I rather like the extra frunk space and on long trips I will be using it to carry a spare tire, since I prefer to be able to self-rescue when I am very far from home or a city.You guys really care about frunk space?
yes, you can. The Model S allows you to software select different versions. For example if you have a P90D you can select the 70D, or just the 70. The car will then limit the performance so that it drives like that lower model. Unfortunately it does not work the other way around ;-)Is it possible to disable the engine in front with dual motors?
yes, you can. Tesla recently pushed out an update for the S that allows you to software select different versions. For example if you have a P90D you can select the 70D, or just the 70. The car will then limit the performance so that it drives like that lower model. Unfortunately it does not work the other way around ;-)
I think it's mostly intended for the sales people so they can simulate different versions you're considering. However, the ability to switch between RWD and AWD would be nice for the reasons posted in the original question.That's interesting. I would never have thought that Tesla would do something like that. Hmmmm
Why would someone pay all that money for extras....and then downgrade through software?
Based on what what Tesla states on their website for the S, duel motors adds 6 miles of EPA range, and reduces 0-60 times by 0.3 seconds. Not to mention better handling. Considering Tesla is charging 3 grand for a 15 mile increase in range, and we know the duel motor on the 3 will be less than 5 grand (I think it will be 4 grand most likely), I'd venture to say that duel motors will be the most no-brainer option on this car.
Thanks for pointing this out.70% of braking force is generated by the front axle. With a single motor M3 you will be wasting all of this as heat on a traditional brake disk, with a D you will be able to recoup some of it. Also, the regen will be much better as it will feel a lot more like traditional braking as opposed to a [not-so] gentle E-brake tug. I'm sure the Model S owners can chime in as to actual numbers.
Seems like a manipulative sales tactic.I think it's mostly intended for the sales people so they can simulate different versions you're considering. However, the ability to switch between RWD and AWD would be nice for the reasons posted in the original question.
But...that first statement is not true. An EV with RWD-only will regen with the back axle until the desired braking effectiveness is insufficient and you need to use the friction brakes. Regen maxes out well below the deceleration possible with only the rear tires, under most conditions. Besides the Model S, the i3, smart ED and i-MiEV have all used RWD regen. For any given deceleration rate and under most conditions, a RWD will regen with the same efficiency as a FWD and AWD.Thanks for pointing this out.
S 60 4323 lb from 2014 Tesla Model S 60 - Instrumented Test@Lunarx I don't know that the RWD saves that much weight over AWD. The 'standard' AWD uses a smaller rear motor than the RWD motor motor. It's not until you jump up to the PxxD that the rear motor is comparable to the RWD motor.
Sure? Yes. Think about it this way, if you lost your front brakes in an ICE vehicle, could you stop? It would no problem in most cases. Max braking deceleration is typically over 1g eyeballs out. Max regen peaks only around 0.3g. Can only the rear tires create that deceleration? Absolutely. With the relatively light braking forces created by regen, a rear motor can extract the kinetic energy just like a front motor.Zoomit are you sure about the RWD regen thing... last time I checked there's much higher torque at the front during braking as the weight of the car shifts forward... Also with a smaller motor up front, this increases the efficiency of the regen due to higher load. A large motor on the back can't get the same regen efficiencies due to far less load.
It's the same reason older traditional cars had disc brakes in the front and drum brakes in the back.
Here's an article on the matter as well BMW i3 versus Tesla Model S 70D
