nwdiver
My house currently has no insulation at all (very old house). While we live on coastal area the temperature fluctuates a lot during the hottest / coldest days. I have been thinking about insulation but not sure which to go with. As mentioned the house does not have insulation whatsoever so will the attic insulation help much? The walls are still not insulated.
I also like to run/add my own network cables every once in a while, will the blown insulation be applied at the attic floor? If yes that will interfere if I decided to run more cables. If it's only applied below the roof then doesn't that also seal in the heat trapped inside the attic?
Spray foam is certainly superior in terms of R-Value per inch. But if you have the room in your attic for a foot or so of cellulose it's ~1/4 the cost. Cellulose will also settle limit air flow through the ceiling. Most homes don't have insulated walls.
You can find blown cellulose at Lowes or Home Depot. If you buy ~20 bags you can typically get the blower for free. With the help of a friend to feed the blower you can usually insulate ~1000sq ft in <2 hours.
My local hardware store included a blower rental with purchase of a pallet of cellulose insulation. Did the DIY blown cellulose job with my wife almost 10 years ago. I made a "slight" miscalculation, meant to add 2' of insulation, but ended up with 4' .. oops, a little more doesn't hurt. Dropped out heating/cooling bills dramatically. Total cost $300.
Yep... adding the recommended thickness of cellulose to your attic is the #1,2 & 3 best things you can do IMO. So cheap. So effective.
