Yes, that's all sensible. I might arrange a service visit and see what they say.
Yes please! Can you make it big and blue too?
My pleasure ...
8% Where does that figure come from? Teslamate? How is it determining that? I'm not sure what there is in the Tesla API data that would allow an accurate determination of that?Looking at the data from Teslamate, it looks as if regen rarely exceeds about 60 kW to 70kw, and then only for a few seconds at a time. Regen recovers around 8% or so of the energy used, roughly, so that would only be about 6 kWh or so for a complete battery discharge, so not really a lot in the overall scheme of things.
Then it occurred to me that when I had an ICE car I didn't care a bit if my range was 5 miles less on a full tank than it was at the last fill up, or that if I had fun rather than being staid i'd lose about 20 miles of range.
Not sure about the total. 8% does not sound crazy though I would like a little more to base it on than just your experience. I'm not sure that would pass peer reviewYears of driving cars with regen and looking at data, and not Tesla specific, but regen is regen and will be broadly similar in terms of recovered energy for any car with it, or at least any car that doesn't apply the friction brakes until a very low speed, normally.
Back when I was into amateur race events we used to work on the basis that the brakes might have to deal with about 20% of the energy delivered by the engine in a race on a fast circuit, but much less when driving on the road. This data was used to determine how much heat might build up in the brakes, how much brake cooling might be needed and basic stuff like the best brake pads to use for a given set of conditions (too hard meant poor effectiveness at low speed, too soft meant too much fade at high speed). Not hard to use the data from the brakes to estimate how much energy they were having to deal with.
But actually thinking about it, Given that dropping from 75mph to 70mph would recover a similar amount of energy to going from 30mph to 0mph maybe motorway driving and town driving are not actually so different anyway whatever the actual figure?
I don't disagree with the basic maths though 2000Kg is a little on the high side unless you have the whole family on board.It's a really hard thing to measure, but about ten years ago some of the more fanatical Prius crowd set about trying to measure it, by semi-hacking into the car and recording live data (can be done is a similar way to the Tesla, I think) they concluded that 8% was about the best the car could ever achieve. Like the Tesla, the Prius doesn't normally use the friction brakes until the speed drops below 5mph, or unless there is a rapid application of the brakes (emergency stop type application), so the read across to any other car with full regen braking is probably reasonable.
Back when I was into amateur racing the cars were instrumented, so we knew how hot various parts of the braking system were getting and also how much cooling air was coming through the ducts. For drag reduction reasons these ducts needed to be as small as possible, whilst still preventing the brakes from getting too hot. As already mentioned, the highest figure we ever saw, for a fast circuit, was about 20% of the total energy in used in any lap being absorbed by the brakes, so that sets an upper bound on regen, one that's way higher than would be seen in road use.
The lions share of the energy goes into pushing the car through the air and overcoming normal rolling resistance, with the former increasing in proportion to the cube of speed through the air. Not hard to work this out, knowing some basic parameters. IIRC, the projected frontal area of the Model 3 is around 2.2m² and it has a published Cd of 0.23, I believe. At 50mph (22.352m/s) the drag force (ignoring rolling resistance) would be 0.5 x 1.225 x 0.23 x 2.2 x 22.352² = ~155 N. The power needed to overcome this aerodynamic drag is going to be 155 x 22.352 = ~3.46 kW. On top of that, energy will be needed to accelerate the mass of the car to that speed, plus there will be power needed to overcome the rolling resistance of the tyres (less than the aerodynamic drag by a lot, and dependent on load, tyre pressure, temperature, surface roughness, surface friction coefficient, etc, so not easy to calculate).
The kinetic energy the car has from travelling at any given speed is the only recoverable element that regen can make use of, as the energy used to overcome rolling resistance and that used to overcome aerodynamic drag is lost, by heating up the air and the road surface. Assuming the same speed of 50mph (22.352m/s) and a car mass of 2,000kg, the kinetic energy will be ~500 kJ, or ~139 Wh, so not a lot, and some of that will be lost as heat to aerodynamic drag and rolling resistance throughout the slowing down period, plus some will be lost due to the loses in the regen system.
If we take a hypothetical and very simplistic journey, where a 2,000kg mass Model 3 accelerates on level ground from a standstill to 50mph, and we ignore rolling resistance, and the drag during acceleration and deceleration (just to over-simplify things), with the car driving for half an hour at 50mph, then it will use about 1,730 Wh from the battery, and could theoretically recover a maximum of about 139 Wh if it could possibly recover all of its kinetic energy during regen braking. That gives a maximum regen of ~ 8.03%.
The number would change a great deal with different circumstances, like terrain, acceleration/deceleration profile, vehicle mass, temperature, etc, but it's not hard to work through a range of different scenarios and come up with the maximum that regen could recover.
The thing I find hard is that no one travels at a constant 50mph or any other speed for any period of time. you are constantly adjusting for bends other traffic etc and every time you lift off you will get a bit of regen which I guess all adds up + the 50-0 at the end. in many of those lift off cases just coasting more and letting friction slow you down might actually be more efficient?? but I think I am probably over thinking this now.
At the end of the day though it is what it is.
I would perhaps worry less about battery degradation, if only I knew what a new battery costs. I think that's an all-important factor in the degradation field, but nobody seems to know.
In practice when you are going downhill you feather the accelerator the amount to keep the car rolling at the speed you need so it's pretty close to coasting ... obviously real coasting would mean in that scenario that the car picked up speed which you would then have to reduce with sudden regen or actual brakes... probably wasteful too. It's interesting to look at the power/regen line on the screen to see when you are balanced between the two i.e. coasting.
