stopcrazypp
That was also what I was wondering. Single phase charging power might be the Achilles heel of the Chameleon charger. From the following thread, it seems the fastest single phase EVSE they offer is 7kW, but it's not clear if the charger can handle more. It might be able to since the max 3 phase charging current is 63A and if you convert that over to 230V single phase that's about 15kW.By the way, this link indicates that the Chameleon charger also supports single phase up to 32 A - quite good and good enough in its home market, but less than half of the reductive charger. It's just a personal blog, though, so it might be incorrect. *edit* Rereading it, it looks likely to be just speculation. Is there any definitive info on the maximum single phase power of the Chameleon charger yet?
http://www.renaultzeforum.com/forums/Thread-Charging-Options
It's not a necessarily a real problem (although in the Roadster maybe it is, since that was an air cooled motor, plus even with a liquid cooled system there is much less air flow when the car is stationary), it's likely less efficient to have to use motor cooling. A dedicated charger would have a cooling circuit designed specifically for stationary usage and sized appropriately for the application.I don't think motor winding overheating should be a problem for a liquid cooled motor. If so, the system is too inefficient anyway.
