Midnightsun
The latch motor does need improvement as it is once again the issue. Seems to last a couple of years at best and then issues start. I am sure it is more likely with cars in winter/salt conditions but eventually all will fail I would think. Just needs to be well sealed to correct the issue.
By the way, I did install the new software which can sometimes get it to work like it should however with a dective latch motor this is only a bandaid fix until the motor is replaced.
