It needs to be 230-ish to achieve maximum range.
That's a little optimistic for a 2020 SR+, the OP's vehicle.
What settings or adjustments can I do to extend my range on SR+? I get about 170 instead of 250 on a charge, that’s a big gap.
If you want to get 250 miles on a 100% to 0% discharge, for a 2020 SR+ (what you have - it is different for other vehicles), you need to see your Wh/mi on the trip meter read about 199Wh/mi. Since you have a brand new vehicle, it's
possible you might be able to accomplish this with ~202Wh/mi.
If you can, post a picture of the screen showing rated miles at the beginning of your drive (
along with the trip meter details), and another picture at the very end of your one-way trip, showing the trip meter (showing miles traveled and efficiency), again capturing your remaining rated miles, with
no time spent in park between the two pictures.
In this post, you can look at the BMS & discharge constants to get an idea of how it works.
2020, 2019, 2018 Model 3 Battery Capacities & Charging Constants
If you don't want to use the buffer (you don't!), you'll only be able to achieve about 95.5% of the EPA range (239 miles) at the
rated consumption of 211Wh/mi. Or, 100% of the EPA range at ~4.5% less than the rated consumption...
Seems like a lot of driving for an SR+! This would be more easily accomplished in an LR, and even there it would be difficult at these speeds in all conditions.
