RedWhite19
Yeah, my two year old 2020 SR+(August 2020 delivery) with just 10,700 miles gets about 220 at 100%.That’s pretty good. My 3yo SR+ only has a few more miles at 100% than that.
Good to know at least one other person has the similar range as my car. I'm right around 193 on full charge, which is down a *lot* from the starting point of 218. I asked Tesla service about it, but of course they had nothing useful to say.
My only ever said Standard Range, I took delivery in March 2020... Yeah, then. $35,400 and some mods later, and this car is a steal. I really like the cheating the system aspect of getting a car this good for so cheap. No Autopilot, just stock cruise control.
My best guess on the lowered range is that I don't run it low very much at all. Lowest I've been is maybe once to 18% or so. I think the pack cannot calibrate properly without seeing a deeper cycle once in awhile. That's tough to do when I've got... 3100 miles total. c-19 has me mostly homebound.
However- lots to still like. It was 102 degrees here today, and no AC in the house. From 4:30 to 6:30 I took my laptop to my car, and ran the AC there. Used about 10% of the battery.![]()
I think you would get more like (186/220)*240 = 203Hello, 2019 Model Standard Range at 34,289Miles only 186Miles at 100 percent. If we unlock our range for 2K should we get the 240miles like the Standard Range plus? Thanks
215-220Miles but after updates drops to 203 and then 196. Now 187miles, location is in Tampa FL. I will try to do the battery calibration now. Will let you guys know. Thanksi think you have the heat issue like I do in AZ. What was it when you bought? How much SC?
So this thread may answer a question I’ve had for a long time. As the battery degrades does the software calculate the degregation into what the standard range has access to? I was hoping that the range the SR would stay consistent as the degregation affects the portion of the battery we don’t have access to (the top 10%) but reading the comments here it sounds like the software over time adjusts this down? I’m at 18k miles (aug 2020 SR build) and haven’t noticed a loss but I rarely drive it long distance to test the true range.215-220Miles but after updates drops to 203 and then 196. Now 187miles, location is in Tampa FL. I will try to do the battery calibration now. Will let you guys know. Thanks
One other thought, based on some recent threads- Does being SR mean we also have a Reserve?
If we drive to 0% charge, do we actually still have 10% range left? The battery knows for sure, I'm less sure the other software will work right, but I think there is a chance this will work because it's based on actual battery voltage, not estimates.
If anyone ever tries this even accidentally, it'd be great to know what actually happens.
No, 0% is really 0%. When you charge to 100%, you’ve actually only charged to 90% (or whatever the number actually is based on how much they lock out to make a SR).If we drive to 0% charge, do we actually still have 10% range left?
The lockout is at the top of the battery, not the bottom.
I'm down to 182 on a full charge. I took delivery 6/30/19 but don't remember what the starting point was. Anyone here confirm it's 218 for all? It even said SR+ for awhile and now SR (should have filed a claim then) . It has been stable at ~180s for a while now and I wonder if it has to do with the heat in AZ. 15% loss? What is warranty % limit on SR?
I agree with you $35,400 is a steal. I also got the fed tax credit, but used part of it toward the AP upgrade. Might ask for unlocking to SR+ IF TSLA still allows it
No longer the same dilemma with the SR Y. Price is close to LR and not really avail. even if off menu like 3 was
Right-o, my bad. It's definitely off the top. Wishful thinking.
Mine got down to 192, from 212 when I first had the car. N. Cal. so not extreme temps, and also only 3400 miles, so barely used.
One thing I did was try the rebalance technique recommended in a different thread, where you cycle the battery for more extremes so that the BatteryManagementSystem can determine the actual cell values, and rebalance them all. I ran the battery down to 6% and left it for a day to idle/detect, then charged to 100% (our 90%) and let it sit there too because 100 is not 100 for us. After doing that, my predicted range went back up to 202.
Also worth noting that I contacted support about the lower range, and they said everything was within spec from the logs and querying the car.
