Finally put ceramic on the car. Some lessons learned.
Discussion in 'Model 3: Interior & Exterior' started by Glamisduner, Jun 10, 2019.
  1. Glamisduner
    Glamisduner Active Member
    Escondido, CA
    #41 Glamisduner, Jun 11, 2019
    They kept the name, but it's been formulated to work in warmer climates:
    This is the video I watched prior to applying and purchasing.
    Use 2.0 for colder climates. (3.0 will still work though).
  2. JulienW
    JulienW Active Member
    Atlanta
    CQuartz TiO2 50ml Kit
  3. jkoya
    jkoya NA2 NSX
    Northern CA
    @Glamisduner - Off topic here, but I really like your wheels !! What manufacturer and what size are they ?
  4. Glamisduner
    Escondido, CA
    #44 Glamisduner, Jun 11, 2019
    They are Titan 7's in 19x9 +35 offset
  5. jkoya
    jkoya NA2 NSX
    Northern CA
    Thanks - They look impressive on your 3 !!
  6. Glamisduner
    Escondido, CA
  7. bgreet
    bgreet Member
    Houston, Texas
    While it was developed with colder weather climates in mind (like the UK), I thought it essentially just had a broader range of applicable temperatures when compared to the original product? Not necessarily that UK is only meant for colder weather environments.
  8. jkoya
    jkoya NA2 NSX
    Northern CA
  9. Mike Robinson
    Mike Robinson Member
    Atlanta GA
    Car looks great and I commend you! I don't have near the energy you do, so I had professionals do it for me: PPF wrap + CQuartz Finest Reserve ceramic coating. The ceramic guy had my car for 4 days, but it looked awesome when he finished! I'm planning to use RELOAD every few months to keep it up.
  10. flashflooder
    flashflooder Member
    Charlotte, NC
    I used the same product on my white M3 and, like you said, it's almost impossible to see the product flashing/curing once it's on the white paint. I think I may have wiped it off too fast, due to this, because my coverage has never seemed that great.
  11. Glamisduner
    Escondido, CA
    That's how I felt too but on the video I linked that compares the 3 products, it sounds like we applied it as it should have been done. 3.0 requires basically no cure time.
  12. Mac Clark
    Mac Clark New Member
    Tampa FL
  13. Zelfiris
    Zelfiris Member
    Ontario
    OP, your car looks great!
    Last time I used Cquartz UK on a black car.. just say I had some trouble with the lighting and I missed a few spots on the hood. Next day in the sun, it looks smear marks all over it. Now applying it to a white car, I'm sure it will even more difficult to see. But if you don't see it, maybe you don't need to worry about it. The protection is still there :)
  14. pete8314
    pete8314 Vendor
    DFW
    You're all talking like the UK is some kind of frozen wasteland in need of shiny cars :) As a Brit now living in Texas, but with a decent amount of experience of west coast weather, there's not a massive difference in summer temperatures. Obviously this week has been a bit extreme, and I appreciate California swapping weather with Texas for the week (it's been lovely!), but generally in the summer the UK is wetter, and less sunny, but still in the 80's. Just dress in layers. And pack a brolly. You never know.
  15. bgreet
    bgreet Member
    Houston, Texas
    :D appreciate the perspective
  16. Hans Schulze
    Hans Schulze Member
    palo alto
    Whats a reasonable price to get this done by a pro? I have small touchups and other issues that i dont feel comfortable doing myself. Thanks for all the info.
  17. Kilotango74
    Kilotango74 Member
    Palmdale, CA
    Great method. The only part I would skip is the washing after the polish. Use isopropyl alcohol and water mix or just the eraser pro and your good. All your looking for is to remove polish residue and by washing a drying you could be re introducing swirls that you just removed. Everything else is just as I would have done and way more than most people I see on this forum doing. I have read so many posts where people buy a coating on without proper prep. What a waste.
  18. Magnets!
    Magnets! Member
    Did a similar 10 hour job on the car, looked perfect and then got side swiped a week later. Still in the body shop.
  19. leporsche
    leporsche Member
    Belleville, MI
    Hey, man! Nice job on the car. It looks beautiful.
    I've had a hell of a time polishing my blue Model 3. There are some swirl marks in the hood, and I've been trying to get them out, but every time I attempt it, it looks no different afterwards. My buffer (Griot's Garage 6" Random Orbital - Griot's Garage) is up to speed 5 and I'm using Meguiars G18016 Safe Rubbing Compound 16 Oz. as my compound.
    I'm starting to think that I need to try a different compound, as this stuff is less expensive than the other products people seem to be using.
    Did you have any particular difficulty in getting swirls out?
    I don't want to mess up the paint, so higher speeds and rougher compounds make me nervous.
  20. slade037
    slade037 Member
    Clifton, VA
    For swirls on my Red Tesla, I use Griot's Correcting Cream with their Orange pad. 4 cross hatch patterns seems to get a majority of it out. I always start with the less abrasive (Griot's Perfecting Cream and yellow pad) in a small test corner and if that doesn't do anything, I go to the next level. There have been a few occasions where I had to use a microfiber pad with Griot's Fast Correcting Cream. What kind of pad are you using? I would say you might have get something a little more abrasive. I like using Griot's BOSS system because it tells/matches you with the right pad and compound.
