InTheShadows
How exactly do you know this? This is exactly how mis-information starts. One example is charging with the UMC while it's in the sun. There is a temp sensor which will cut back charging even though the ambient temp is in the 60's F. That is a crappy design, that shouldn't be the customers problem. The clipper creek units do not do this, they sit outdoors, and charge up to 80A.
Your UMC in the sun is a completely different topic. That is in no way related to the firmware update. My post is not miss information.
If your car is not charging at full current there is likely a power issue that is causing it, potentially one that could cause loss of property or life due to a fire.
If you call your utility and let them know they will very likely send a technician out with meters and tools to analyze the problem and probably at no cost. (They like you, you are a big customer) All it takes is a phone call, tell them your electric car won't charge at its full rate and you would like them to check the power coming from the transformer while you are charging so the problem can be fixed.
If the issue is on your side of the meter they will let you know (and possibly what the problem is) and you can then call an electrician and pass the info on to them and they will fix it for you.
