mknox
199 volts is too low. They probably used the 3% rule. So anything less than 201v on a 208v circuit and 232v on a 240v circuit will get you a derated charge.
199 volts is within the normal operating range of a 208 volt circuit. Not sure if that 14-50 was on a 120/208 volt or 120/240 volt system, but in any case, the car should be able to accept 199 volts.
