hans
P631
Noticed a few things in 5.8
- If you get into a sleeping car with music playing, the volume control on the steering wheel takes a few seconds longer to become operational than the center console volume controls.
- The center console map clearly uses scalable vector graphics rather than the static tile images from 4.5
- If you want to get the largest amount of your trip visible in the screen at once, use thumb and pointer (i.e. multi-touch) and rotate the nav directions so that the car is in one corner of the display and the destination is in the diagonally opposite corner (I like bottom left for the car, top right for the destination). As you get closer to your destination its easy to pinch/stretch out to keep the full screen in use.
- backing into a parking spot will often put the heading of the car (and the entire map in heads up mode) backwards. Heading is clearly calculated by using multiple position samples rather than compass direction.
