Keep in mind the light bulb will burn out (like a fuse) under substantially less current than the DC-DC is capable of, potentially even under the current it would see under normal use to charge the 12V battery. So, this may be futile... but would be my first test as well.
But, again, if you're seeing 11.9V on the 12V battery I would suggest charging that with an external charger 100% first, probably to ~14.5V.
So battery side of the terminal has battery voltage, around 13.5av and DcDc side voltage changes 4 to 9V every second. Lightbulb is flashing
I'm still concerned as to how the heck that 225A fuse popped, but, have to start somewhere. It at least appears that the DC-DC is trying to do something anyway.
It is connected instead 225Amp fuse. Car is NOT showing low voltage message anymore. But the car was on jumper cables from my truck
The actual connector on DC-DC is good, plug that goes to DC-DC signal was damaged and now fixed. However i replaced my original DC-DC with another one because mine was all smashed. Maybe it shorted to the ground during the accident somehow like Otmar said.
Ok, so i connected jumper cables to the car, the connected 12v battery with approx 12.4V on it. Car starts all good. No messages. Voltage on the battery side is 13.5V on the DC-DC 4-9V. Then i disconnected the jumper cables. The lighbulb started to blink about twice faster!!! Voltage on battery side is 12.2V on DC-DC 4-7 V. I sat in the car it started, no messages, after about 10 seconds i got message that 12v battery is low, unable to drive.
I'd suggest shutting it down, disconnecting the 12V battery and then replacing the 225A fuse and powering it all up again.
