Old one was all smashed and water inside.
Hello! Thank you so much for your reply. Im trying to see if i could put third party dcdc converter to make my battery charge from battery pack. I will see if you can get another dcdc converter to install and see if its gonna change anything, because i dont know how to check this converter to check what is wrong dcdc or CAN signal problem. Maybe you could explain one more time in details with parts that i need to buy from the web site, so i could buy and try if its gonna help. Thank you again. I with you were closer.))Yes, it could be a firmware mismatch between the old one and the replacement. Because it's an intelligent device (CAN bus proves this), if it doesn't see something it's looking for on the bus, it may not start up. It could also be getting bad information. It seems like it's ok, as the flashing bulb when it was in series proves it was at least pulsing a few amps.
Too bad you aren't closer. I'd be happy to have a look if you were.
You could always put in a different DC-DC. All it's got to do is take in 200-400VDC and put out enough to keep the systems powered. Probably needs to be at least 750W to run all the Tesla's on-board systems. You can probably just take a $150 15V switch mode power supply and wire it in. (be sure to adjust the voltage down to about 14) I know the Mean Well units are quite happy on DC. (I've used them on EV conversions on many occasions)
You should leave the Tesla unit in, as it also distributes the high-voltage to the heaters and A/C compressor. Tap off the A/C compressor HV lines and wire it to the AC input of the power supply, then wire the output of the power supply in parallel with the heavy +/- terminals on the Tesla converter. Obviously if you aren't 100% sure of what you are doing around high-voltage DC, do not attempt. The car's HV bus is definitely lethal!
Also, Before you wire in any switch-mode supply, open the unit and verify that it has at least 450V rated main capacitor(s). If it's only 400V, you'd be cutting it too close, so you'd want to upgrade it to a 450V minimum cap first.
This is probably a good idea. Lets try to Replace the main board first.
