BrianMan's cheap and quick, no-drill front license plate
Parts required:
Tools required:
Installation process:
1. Make oval shaped holes vertically oriented into the license plate holder that are large enough for zip ties to easily pass through. A pair about a half inch above the left and right large holes that the holder came with. You'll want each pair about a half inch separated. [I used a drill but a dremel, knife, or screwdriver would work.]
2. Bend the "entry" end of two cable ties 1" or 1.5" from the end to make a V or L shape. L is good enough, but V is easier later.
3. With your left hand, position the license plate holder where you want it vertically. With your right hand, use your license plate to help position the holder horizontally relative to the T(esla) logo. Transition both to your left hand and lean back, left, and right to verify you like the positioning.
4. Remove the license plate, attempt to wiggle the holder to verify it's at a stable location. Return to step 3 if necessary.
5. Mark the horizontal location of your holes from step 1 with masking tape on the cone.
6. Push the cable tie through the right-most hole of the right-side pair of holes from step 1. Reinforce the bend from step 2. Push the cable tie end through a honeycomb hole on the right side of the last full row and horizontally aligned with the right edge of your masking tape. Maneuver the cable tie end through the neighboring honeycomb hole to its left.
7. Push cable tie end back through the neighboring hole of the right pair and then through the clasp. Note that you want to stop at the first notch in the clasp so that (a) it's a reasonably firm hold (won't come loose) but (b) doesn't restrict movement too much for the next tie.
8. Do steps 6 and 7 with the left cable tie, wobble the holder to the position you like, and tighten the straps.
9. Clip the excess cable tie ends.
10. Remove the tape, screw in your license plate.
Notes:
Parts required:
- License plate (Government-provided)
- Front license plate holder (Tesla-provided)
- 2x small strips of masking tape (0.5" x 0.5" is plenty)
- 2x Cable Ties, 8.0"
- License plate screws x4 (Tesla-provided)
Tools required:
- Torx bit (to match Tesla screws)
- Drill, dremel, knife, or screwdriver
Notes:
- Props to the Ford Thunderbird forum members that inspired this approach.
- Yes, my car needs a wash and my garage is a mess.
