rbergquist
S946 - VIN 1017 & M3 2327
Re: I have a Signature so we could not remove the nose cone; even called my local service center and talk with a tech who said basically try ANYTHING so you don't have to remove it its is almost impossible to do hence the production changes.
In the end we shined a flashlight up from the outside grill toward the radiator top and could see some light coming thru. That lead to an area of the (attached) nosecone we could drill a small hole in for the cable and pry the grill open to fit a wire thru. Taped the cable to the wire, and get the cable routed.
I've also got a Sig and have been held up on the cable routing behind the nose cone. If you have any more details or pics on how you did the cable routing and hole placement I would find that very useful. Thanks.
