+ me@widodh I'll sign your letter to Tesla emphasising the NEED (not want) for 3-phase and CHAdeMO Model S charging in Europe
Who said that 3-phase was not important? Tesla or RWE?i talk to JB Straubel yesterday. He mentioned the DC as quickcharging. There i could connect any external charger i like. he mentioned also the problems wih powercorrection with 3 phases. i learnt later that there are up to two 10 kW charger on board. it may be possible to pu them on different phases. but there is not enough space to place a mennekes inlet socket into the small hole for the new sleek tesla connector. it was also said, that a person was send over to germany to talk with RWE and Vattenfall about the need for 3-phase charging. the result was, that 3-phase charging is not important. i hope, that the homologation process will force the 3-phase charging for higher rates then 16A as being the standard in europe.
sounds cheap :wink:tesla make external DC chargers out of 9x 10 kW on-board chargers
these seems to contradict your previous conversation with JB Straubel regarding 3-Phase support. Do you think they understand the importance of 3-Phase in Europe?i talk to JB Straubel yesterday. He mentioned the DC as quickcharging.
...a person was send over to germany to talk with RWE and Vattenfall about the need for 3-phase charging. the result was, that 3-phase charging is not important.
3 separate chargers require much more (heavy, costly, inefficient, and bulky) components than one charger taking 3phase input for the reasons quoted by Eberhard. So I doubt this is the best way to go.
tesla make external DC chargers out of 9x 10 kW on-board chargers, powered by 3-phases 277/400V with 120A. Tesla wants to install those chargers in Europe too.
Sounds to me like a good way to take advantage of the higher production rates of those 10kW chargers, since they will be making 20,000-40,000 annually for Model S consumption. They are already designed to be paralleled (one or two in the car)...sounds cheap :wink:
sorry but I don't think this proprietary system will compete with CHAdeMO given that Nissan alone expects to sell 5,000 of the new ~£8K (~$12K) unit by March 2016Sounds to me like a good way to take advantage of the higher production rates of those 10kW chargers, since they will be making 20,000-40,000 annually for Model S consumption.
don't forget that the Leaf gets 32A single phase charging in 2013I think the Volt and Leaf have 3.3 kW chargers partly due to US utility companies suggestion to automakers that it will be easier for them to manage.
It won't be elegant, but it would at least be usable.doug said:An adapter for CHAdeMO would need to incorporate some active electronics to translate the signaling.
So, I spoke directly with people who would be in a position to know, and when I asked them about that they indicated that they are keeping it proprietary for now. I gather their focus is getting their solution working for themselves with their own control over everything, and they will think about the option of opening it up to others later.It will be interesting to see if Tesla releases all the specifications into the public domain, and tries to convince SAE, IEEE, ISO to publish design standards, and to convince other firms to adopt it.
That is a option ofcourse! A small external DC charger would be fine with me. I don't see Tesla changing the charge port.There might be an easy solution for 3-phase charging.
The existing chargers take AC in, rectifies it and runs it through a DC-DC converter. It is easier to rectify 3-phase than single phase. If the chargers can take DC input instead of AC (no reason they should not be able to do that, DC will just pass through the internal rectifiers) one can use an external 3-phase rectifier built into a (bigger) version of the UMC and feed the chargers DC through the Tesla plug.
3x16A could provide 10kW of power, 3x32a 20kW.
Does anybody know how big the rectifier would be and typical loss (=heat) ?
Just because some people want it doesn't guarantee they will build it. I don't think it is a priority for them right now.That said, I'm sure an adapter will be created to take advantage of the CHAdeMO infrastructure...
