eledille
TMS 85 owner :)
It could be that 3-phase is allowed, although I don't think so.
Google: international standard IEC 62196. Check page 9 of top result. Mode 1 is up to 16 A, single or three phase, up to 690 V, any socket type allowed, no control signal or pilot pin required, no inline control box required. Disclaimer: This version is withdrawn, but this is the same as I've read elsewhere.
However, you will end up with a box in the cable like the Roadster has.
That seems to depend on whether local regulations are stricter than IEC-62196 or not, plus possibly whether the manufacturer wants to sell you expensive, unnecessary gear...
That box does the communication to the car and lets you charge on CEE 32A 5p.
For 32 A, a control box is required by IEC-62196, yes.
There will have to be some kind of logic outside the car, otherwise the car won't be able to detect the Amperage.
I think it's the other way around, but by all means please correct me if I'm wrong, I'm just an amateur and enthusiast. If the car tries to pull more than the socket is capable of, all that happens is that the fuse trips. The car decides how much current to draw - but if the car does not behave in accordance with the spec, the fuse will trip and its owner will be less than impressed. The protocol tells the car how much it can pull without tripping the fuse.
You could even make your own portable EVSE with the Open-EVSE project. That would be sufficient for 3-phase charging on any socket
Yes, and then pay an electrician to verify it, in order to not void the insurance... I'm joking, if prices are too high, then that might be a possibility.
