Something else to keep in mind -- the Model S already has contactors to allow for dual-mode charging (either AC or DC) on the same charge port conductors....you have no space for a contactor or one, thats can do 1200A with nearly no contact resistance.
(somewhat off-topic) I would be interested to see the wire paths in the Model S between the charge port, one or more chargers under the rear seats, and the battery pack. Where do these DC-fast-charge contactors reside? Are contactors also necessary on the input side of the AC chargers? How are the dual chargers "wired up" to the charge port and battery pack? etc...
http://www.acpropulsion.com/products-reductive.htmlThe Reductive charger uses the motor and IGBTs from the drive system to serve as the power elements of the charger. When the EV is being driven, the drive system works normally. When the EV is being charged, the drive system is re-configured as a charger. In this way only one set of large, heavy, and expensive components is needed.
@eledille: this sounds like a great item to put on the "to do" list for Tesla's EEs. I'd be very surprised if we see it on the EU Model Ss, because of timing, but it would be a very cost-efficient way to handle 3-phase charging in later iterations.
And anyways, it looks like the Max single phase power is 3kW for the Renault, which is pretty much the slowest you can get in the US for level 2 charging. Tesla is offering 10kW and 20kW right now, so that charger will have to be beefed up.
In terms of the "integrated" charger. I think Tesla has used this before in the Roadster. I assume we are talking about the charger in page 18 of this presentation:
The Renault charger sounds exactly same as the "reductive" charger technology from AC Propulsion described below, which Tesla used to license and use, but ditched later on for a separate charger (because the separate charger was actually cheaper, supposedly).
Therefore I think even Nissan/Renault will have to license from ACP if they decide to use the same system in the US.
agreed... I was told at the Geneva show by Renault that it was a "minimum of 32A and possibly 63A"I don't see that. I read it as the MIN single phase power is 3kW.
http://www.greencarsite.co.uk/electric-cars/renault-zoe-with-Plug-in-electric-car-grant.htm
- 3kW (16A single phase wall box) = 9 hours
- 22kW (32A three-phase charging station) = 1 hour
- 43kW (63A three-phase charging station) = 30 minutes
I'm just commenting on the likelihood of it. I certainly know the European market will likely have a different charger (it's going to be the same way for J1772 vs Mennekes), but I see the modular approach more likely (given Tesla has ditched the integrated approach once before and it's easier to swap out a modular charger). The integrated approach will mean licensing issues for Tesla which might end up costing more money anyways (if Renault has patents, which I assume is in Europe, that means Tesla will have to pay both ACP in the US and Renault in Europe).But I thought you guys were uninterested in three phase - I imagined this would be for Europe and Tesla would install the current chargers for NA.
you have to include the fact, that all of the DC charger with 50kW or quick charger with 90kW will be feed from the 277V/480V 3-phase grid. That would enable any electric car to charger with 22kW or 43kW from the AC-3phase grid as well without the need of an expensive external DC-charger.
None of the three-phase sockets you guys are talking about are readily accessible to the public. Plus when you are drawing at that rate, the owners of that socket will likely want to charge you for it (esp. given there are little to no 3-phase sockets used in residential settings). And given J1772 has no support for 3-phase whatsoever, unlike the Mennekes connector standard Europe will use, there would be no existing level 2 stations (which have the payment system built in) that would support 3 phase charging. 3-phase will have virtually NO role in the US for that reason. That's why there's not even one automaker planning to offer 3-phase in the US (even the European ones, like BMW with the Active-E). Therefore, Tesla has absolutely no incentive to support 3-phase in the US. Any built in 3-phase support will just cost them extra money in the US and will not play any significant role in helping sales in the US.My comment about American disinterest in three phase was a bit tongue-in-cheek. Sorry. To me, three phase is obviously desirable in NA too, and personally I'm sure that will become more and more evident. The lack of plug and standards support is a challenge, of course.
Again, I'm not sure if you missed my other comment, but the car you are pointing out not only doesn't include the cost of the battery, it also will be made in about 10x as much volume as the Model S. Plus Renault doesn't have to pay any licensing fees presumably (like Tesla did before). It's just not going to cost the same for Tesla to make it. And keep in mind my point above about the significance of 3-phase in the US.If the alternative is USD 3000 for two extra chargers to get three phase (number off the top of my head, may be wrong), and then at only half the power of a small, inexpensive car, then perhaps they should consider licensing. But patents can often be worked around, you just have to find a sufficiently different way to do the same thing. Maybe that is possible, maybe not. Tesla needs to develop its own IP in this field as soon as possible, if at all possible.
