Yggdrasill
Assuming a weight of 20 kg, that's about 50 Watts to keep it going at 55 mph. That reduces the range of the 85 kWh battery by about 1 mile, and will cost around 200 kWh over 300k km.12kg? that's the weight of the 22kW Brusa Charger, less then one of Teslas onbord charger which are 15kg each.
DC charging makes only sense with high power like 90kW quick charging, but then it would be better to draw the power form the medium voltage of 10kV or 20kV system via a AC - DC Converter down to 500V DV, saving the need and avoiding the loss (3-5%) of a transformer.
This may work for future quick charging stations on highways to replace the current gas station.
That's not as bad as I would have thought, actually. It may be that the AC charger is worth dragging along in the long term.
