Gen 3 wall connector power sharing
a1machinista1
MY5 5/24 wh/blk 19" tow-- MSLR 6/1 MSM/blk 19"
Apr 12, 2019
871
684
oregon
We have an electrician coming so this is not a "how do I" thread, It's more for me. I THINK the electrician is going to run a sub panel off of an existing sub panel. The breaker in the existing will be 60a with a run to two 60a breakers in the new sub panel. Those will feed our new wall connectors. If power sharing is not yet enabled between gen 3 connectors then how will this work? I am assuming that both cars can not charge at the full rate since they both share 60a. Will the cars self regulate to not overload the single 60a supply in the first sub panel?
Sophias_dad
1,899
2,110
Massachusetts
Without power sharing, you can only set each HPWC as if it has a 30 amp breaker, or opt to only use one connector at a time.
The good news is that power sharing is now supported on Gen3 HPWC's.
The cars won't self regulate at all. They only know what the HPWC tells them they can have, current wise.
Reactions: Acps110 and Rocky_H
a1machinista1
Apr 12, 2019
871
684
oregon
Oh!!! I was under the impression that the power sharing update had not yet been released. Well that answers my question. Ok let's say that power sharing was not yet enabled, would it be possible to (split) the feed to 40a/20a or would it have to be 30a/30a?
Sophias_dad
1,899
2,110
Massachusetts
It could be 40/20, or maybe even 50/15 without tripping the breaker.
Reactions: Rocky_H
a1machinista1
Apr 12, 2019
871
684
oregon
So we had the install done today. Totally different then what I was expecting.
a1machinista1
Apr 12, 2019
871
684
oregon
And totally against the installation manual. I also wonder what's under those GLOBS of electrical tape!
I think they are called Polaris connectors. And I think this install is ok. Been in this forum for the last 3 hrs reading. I will call the electrician in the morning. Don't have the cars yet so I don't need to use them.
Power sharing support with Gen3 HPWC is great news. Question… I park 2 Model 3s in my garage, which also has the main electrical panel for the house. The panel has a single 60A breaker that was intended to feed 2 Gen2s by way of a junction box that would send power to each one, that would also be connected by a data cable. Tesla’s demise of the Gen2 WC caused me to change direction. I now have two Gen3 HPWC units ready for a power sharing installation, but existing wiring is still set up for Gen2 power sharing.
I assume That I should remove the junction box and install a sub-panel instead, with two 60A breakers, each sending power to one of the Gen3 WCs To be installed. Once the Gen3s are connected by WiFi and using the power sharing feature, I assume power to the Gen3s will be limited to 60A total. I would be very grateful for confirmation that this is what my electrician will need to do to set up power sharing with my 2 Gen3 WC units. Any clarification would be great! Thx!
Reactions: Rocky_H and brkaus
Sophias_dad
1,899
2,110
Massachusetts
Yes, that's how its supposed to be done.
Reactions: Rocky_H
a1machinista1
Apr 12, 2019
871
684
oregon
That was my understanding going into our installation. The manual states that each connector needs its own circuit. BUT it also shows hook up without a sub panel. Our electricians employee hooked up our two Gen3s via junction box WITHOUT individual breakers. There have been statements made both in favor and against how our electrician installed these. Luckily we don't have either of our cars yet so we have time to figure it out. I would say talk it through with your electrician and don't be afraid to ask questions. Our electrician who we have used for multiple projects was very open to the discussion I had with him. Remember this is all new technology that everyone is incorporating into our lives and that some electricians are still learning about. The owner and the electrician are coming over tomorrow and we are going to discuss the installation.
Sophias_dad
1,899
2,110
Massachusetts
Right, per page 24 of the installation manual, a subpanel is not required. OTOH, even without a subpanel you are expected to have individual branch circuits to EACH wall connector, also per page 24. That's just how it is, I'm not saying I agree it should be required.
