Glad I Got The Towing Package Option!
Discussion in 'Model X' started by dreamwave6, Jul 13, 2017.
Tags:
  1. dreamwave6
    dreamwave6 Member
    San Diego, CA
    I just took delivery of my X 90D about 2.5 weeks ago. I ordered my 90D with every available option, including the Towing Package. I just spent the past week moving locally from one house to another. I rented the largest enclosed trailer that U-Haul offers and towed it with my Model X. The experience was outstanding. Given the weight/stability/low CG of the X, the towing stability was unprecedented...much better than what I've experienced with my previous BMW X5 and X3. The battery range was also impressive. All in all, the Model X is clearly a great towing vehicle!
    19800706_10211918241644084_855976939720284812_o.jpg UNADJUSTEDNONRAW_thumb_871d.jpg
    • Like x 9
  2. Peteybabes
    Peteybabes redneck drivin' a tesla...
    'murica
    what kind of distances were you towing? also do you know the approximate weight you were towing?
  3. Tam
    Tam Active Member
    Visalia, CA
    If you don't mind: How do you connect those electrical wires to the trailer lighting system?
  4. anicolao
    anicolao Member
    Canada
    I'd check your rear tires for wear right away and record the tread - Tesla claimed that a single towing trip destroyed my rear tires (it was about 2,000km with a lightweight trailer like you show here).
    alex
    • Informative x 2
  5. dreamwave6
    dreamwave6 Member
    San Diego, CA
    I towed between homes in neighboring towns that are about 10 miles away from each other but getting between them, involves going up and then down some pretty steep elevation. Regenerative braking definitely helped recover some energy when going downhill!!!
    I was towing about 2500 to 3000 pounds at a given time.
    Andrew
  6. dreamwave6
    dreamwave6 Member
    San Diego, CA
    Tesla uses a circular 7-wire connector which most trailers don't use. Most trailers use a flat 4-wire connector. Thankfully, U-Haul had an adapter that connected the two like a champ.
  7. dreamwave6
    dreamwave6 Member
    San Diego, CA
    I'm not at all concerned. I have a road hazard warranty from Discount Tire for all of my tires.
    Andrew
  8. fwgmills
    fwgmills Supporting Member
    Roanoke, TX
    The flat 4 wire connector is for trailers with lights only. If memory serves, the 7 wire connector is for lights, trailer brakes and 12v auxilliary power to a trailer for charging a trailer battery.
    • Informative x 2
  9. ⚡️ELECTROMAN⚡️
    ⚡️ELECTROMAN⚡️ Fritterer and waster of hours in an off hand wayer
    Portland, Oregon
    Would it tow this very well?:
    I haven't read about anyone pulling a boat with their X, but I think it might be within the pulling capacity rating. Isn't the X rated at 5,000 lbs?
  10. Yinn
    Yinn Member
    Behind you
    Should tow it fine. You're correct, the limit is 5,000 lbs
  11. Sandiegodoug
    Sandiegodoug Member
    SAN Diego
    It would.
    There is a utube video on line of someone pulling a large boat.
  12. Tam
    Tam Active Member
    Visalia, CA
    Thanks for your answer and for posting a very informative thread.
  13. sreehyd
    sreehyd Member
    Hayward Hills, CA
    When towing , Is there an indication or way to look how much weight/load the car is pulling ? If NOT how would we know the load we are about to pull ?
  14. Heart of Gold
    Heart of Gold Member
    Norway
    Here is the video of Teslabjørn towing a 5000 lbs boat over a mountain.
    • Informative x 2
  15. ⚡️ELECTROMAN⚡️
    Portland, Oregon
    Impressive. Any idea how badly range is affected? Just wondering what lakes I could reach with an X75D pulling a tournament ski boat with camping gear. Detroit Lake is 100 miles away, but there is super charger located in Detroit, OR. The trip has 2,270' elevation drop with 3,330' of climbing for a net elevation gain of 1,760'.
  16. DrivingRockies
    US
    You need to know how much the trailer and the load weighs. Also VERY important is tongue weight.
  17. Yinn
    Yinn Member
    Behind you
    Weigh stations. For tongue weight, you could weigh it on a scale or purchase a hitch that has a build in scale.
  18. sreehyd
    sreehyd Member
    Hayward Hills, CA
    Thats a good idea, Thanks ..
  19. Peteybabes
    'murica
    the trailer should have a data plate showing it's weight right? then know what you are putting on it i guess.
  20. sreehyd
    sreehyd Member
    Hayward Hills, CA
    I dont know , If trailer would be carrying one ? We usually see the "Tear Weight" mentioned on 16 wheeler right next to driver door. I would imagine the trailer should carry similar specification.
