So, I got this from Tesla. Anyone able to charge greater than 1.6?
“Grid charging will be limited to 1.6kW per powerwall roughly, outside of Storm Mode being active where it will be higher. This is expected behavior. The system should be working as expected.”
h2,
My single PW typically grid charges at 3.3 kW. I am set to Grid Charge, Export Everything, Time Based, EV2A with $0.03 lower price on exports. My customer login "summary" shows Site Export Limit as 8.05 kW and Conductor Export Limit 30A, which is 7.2kW at 240V.
On sunny days, almost no grid charging happens. Back on 11/5, however, it started grid charging after midnight at 3.2kW till till it reached 91% around 3AM. So this pretty much disproves your 1.6kW limit.
The
spec sheet has a note: 2 In Backup mode, grid charge power is limited to 3.3 kW. This is also the charge rate at which various specs are measured, per note 1.
What I find interesting is that it appears to (secretly) use weather forecast to decide when to grid charge. Nov 4, the day before that midnight 20% to 91% charge was sunny enough for solar to reach 100%. Nov 5 was cloudy, only 4.8kWh of solar, so grid charging was a good idea. But rather than wait till it needed to charge before the 3pm rate increase, it did it in the middle of the night. It appears that it used the weather forecast to make this decision.
What also is odd is that sometimes it grid charges at random night times at random rates. Not a lot, but on obvious reason.
I think the Site Export Limit was derived from my PT&E PTO, basically the max the approved solar could produce, and hence the amount of grid export they "designed" for. Perhaps too much export in a neighborhood could cause
unintentional islanding in a grid failure? Some interconnection rules, no doubt. The Conductor Export Limit matches the single PW max output current, so perhaps that is what that means. I get to these by ethernet or WiFi access to the gateway, Customer login, Summary page.
SW
