Has anyone gotten an aux video/audio input into the display?
Discussion in 'Model S: User Interface' started by Cashoverass, Jun 1, 2013.
  1. Cashoverass
    Cashoverass Member
    United States
    Has anyone successfully put an auxiliary input on the the display? Dvd player, bluray player, ps3, additional cameras?
    With the rear view camera, there's obviously a video input going into the display, I wonder if there would be a way to split and splice into it.
    This would also solve my no-cd-player issue.
    Also, has anyone been ballsy enough to tinker with the display? anyone have pictures of what's back there and the inputs, etc back there?
    I've done plenty of successful tinkering on my old cars and usually have no problem taking apart and putting back together the dash components, but this car is obviously a whole new ballgame.
  2. ohmslaw
    ohmslaw Member
    Silicon Valley
    Don't think it's obvious there is a video input. More likely it's a digital camera that communicates with the CPU via USB or Ethernet or the like.
  3. PhilBa
    PhilBa Active Member
    Seattle
    I have been wondering about this as well. Regardless of the physical interface, it would be nice to have a way to use the display or parts of the display for external devices. Like a radar detector status for example. Perhaps that is the wrong question - is there a developer's guide?
  4. Rheazombi
    Rheazombi Member
    Boston
  5. Chris TX
    Chris TX Active Member
    Dallas, TX
    Just get a bluetooth transmitter and link it to the car. You'll have a wireless AUX IN.
    They are all over Amazon.com
  6. Rheazombi
    Rheazombi Member
    Boston
    Brilliant! Didn't consider that the car can use bluetooth devices other than phones. :tongue:
  7. jerry33
    Texas
    Well, it can only use them if it has the correct BT protocol (called profiles in BT-speak). Most BT implementations only have a small subset enabled. No harm in experimenting though.
  8. Rheazombi
    Rheazombi Member
    Boston
    #8 Rheazombi, Sep 14, 2014
  9. encryptededdy
    encryptededdy New Member
    New Zealand
    That won't work because it's a receiver (used for adding bluetooth to cars without bluetooth). You need a bluetooth transmitter :)
  10. mmh
    mmh Member
    SLC
  11. Chris TX
    Dallas, TX
  12. Rheazombi
    Rheazombi Member
    Boston
    Good to know!
    Will definitely try that. Thanks! Will report back on my findings ~
    If it works I will bake you a blueberry pie!
  13. Skotty
    Skotty 2014 Model S P85
    Kansas City, MO
    I'll eventually be looking to do this as well. I have a weekly 2 hour drive and it's perfect for listening to a movie. With my Volt, I just pop the DVD disc into the car's DVD slot and I'm good. With a Model S, I should be able to bring along a portable DVD player, link it to a compatible bluetooth transmitter, and get it to play out of the car's speakers. Not nearly as neat, but hopefully it should work. I hope future Tesla's will at least have an aux in audio port, as that would make it a little less clunky.
  14. john01
    john01 Member
    Provincetown, MA - Mahopac, NY
    You can only use one bluetooth device at a time. Example, you cannot use your phone and listen to a iPod mini at the same time. One of them must be disconnected.
  15. wycolo
    wycolo Active Member
    WA & WY
    > listening to a movie [Skotty]
    Rip the audio using Audacity as flac/mp3 onto a flash drive at home desktop. Then just play thru usb port as you drive (there is an audio input selection for doing this, right??).
  16. Rheazombi
    Rheazombi Member
    Boston
    Update: Tried the Amazon.com: TaoTronics® TT-BA01 Wireless Portable Bluetooth Stereo Music Transmitter (Not A Bluetooth Receiver) for 3.5mm Audio Devices (iPod, MP3/MP4, TV, Kindle Fire, Media Players...) + 3.5mm Female to 2 RCA Male Cable: Electronics and it did not work. The Model S was unable to pair with it in discovery mode. This may be because the device is Bluetooth v2.1 and the Model S uses 3.0. I heard from someone the newer Model S might even use 4.0. Anyone know?
    I would think that Bluetooth would be back-compatible tho...
    Anyway, so my next step is to double check that the device actually works by attempting to pair it with some other things, and then maybe returning this thing and trying something else. Amazon doesn't have a lot of options tho...
    I'm wondering if the solution may eventually end up involving my smartphone as the middle-man between a device and the car.
  17. mmh
    mmh Member
    SLC
    Well that's really disappointing to hear, I was planning on buying one of those so I could use my favorite MP3 player in the car. In fact I had it in my Amazon shopping cart.
    Please let us know if you get it to work with anything else, maybe, you just got a dead one?
  18. Rheazombi
    Rheazombi Member
    Boston
    Just successfully paired it with my Jambox and it works really well actually. I'm probably going to keep the thing after all and use it for other purposes. lol
    I'm still not sure why it didn't work with the Tesla - perhaps a call to the Service Center might be helpful.
    Additionally, I just now chose to update from 5.12 to 6.0 so I'll try it again once that install completes.
  19. Brightonuk
    Brightonuk Member
    Plantation
  20. swegman
    swegman Active Member
    No camera other than the Tesla camera will work with the 17 inch touchscreen. That is why artsci's camera switch requires a Tesla camera for the front of the car. The touchscreen does not communicate with any other camera.
