? It should be just a black and red wire once you splice open the cigarette adapter cable jacket. If you are seeing bare metal you’ve pulled off the wire jacket. Then you just use T tap or positap to tap into dome wire.woven metal sheath
The wires are super thin. Yes it does matter what size to use because there’s limited space and if you don’t use the right size you will have problem connecting the super thin wires of the blackvue. Earlier posts suggest the red ones (20-22awg).T-Tap, Posi Tap, does it matter what size you use? Sorry, this if foreign to me so want to make sure I use the right ones. Thanks.
Got it, thanks!The wires are super thin. Yes it does matter what size to use because there’s limited space and if you don’t use the right size you will have problem connecting the super thin wires of the blackvue. Earlier posts suggest the red ones (20-22awg).
Ok, was confused with the description. Will give it a shot this weekend. Will also document it so other people can follow.? It should be just a black and red wire once you splice open the cigarette adapter cable jacket. If you are seeing bare metal you’ve pulled off the wire jacket. Then you just use T tap or positap to tap into dome wire.
Holding you to it.Ok, was confused with the description. Will give it a shot this weekend. Will also document it so other people can follow.
So from the Blackvue Cigarette adapter cable:
The Red wire --> Yellow dome light
The Black wire --> Black rear dome light
right?
If you get a chance, can you post a pic of your connection? It would help a lot! thanks.
How do you wire the woven metal sheath as ground on the blackvue cable to the dome light black cable?
So does anyone have any video showing the actual hookup/connection using the domelight yellow and black wires with the dashcam? The video in the original post shows how to access the wires, but doesn't show the actual dashcam connection.
Can someone who has done this take a video or post some pics on how they tapped their wires? thanks!
Still worth installing with the Tesla Dashcam now working?
I use my BlackVue for recording while parked. And it’s better footage.Mostly personal preference. Do you want recording while you are parked? rear cam? May be features in the future but who knows when.
The TeslaCam isn't really working per se, at least not reliably. It keeps corrupting the drive rendering recording stopped. Another issue is the 1-hour limit of rolling recording. Once you fall outside of the hour you won't be able to locate the footage any more if you didn't press the button and that only gives you the last 10 minutes. It's such a hassle to use.Still worth installing with the Tesla Dashcam now working?
Did you make an installation video for us?![]()
Still worth it to have an aftermarket camera for me because the Tesla dashcam does not record a wide view of the front of the car (front of car and sides are not as visible), does not record the rear, and does not record when the car is not on. Not to mention that the Tesla dashcam is not as reliable for most people yet (people still have issues with their USB drives becoming corrupt after a while).
By the way, I just removed my Blackvue B-112 backup battery from my Model 3 because my 22 mile commute was not enough to charge it up to last a 10 hour work-day. I wired into the harness in the headliner (which was my plan all along before I even got the car). And I mounted the Blackvue DR750S-2CH front camera onto this mirror mount from EDR Auto (cheaper than the Blendmount). Overall turned out well, but if I could go back and do it again I would have paid extra for the Blendmount and would have never bought the Blackvue B-112 battery.
View attachment 350146 View attachment 350148
