Is anyone else having troubles getting a LiftMaster set up on firmware 4.2? I'm not sure what else to try!
Have you tried putting the existing clicker in the frunk (toward the nose cone) for the learning step? Several posts have said that got the headlights to blink confirming the code had been learned.
Thanks for the great tips, all. I placed the remote exactly as rlpm said above, and it worked very quickly.
Yes, my Homelink seems to program but when I press the saved profile to open the gate it does not work.Is anyone else having troubles getting a LiftMaster set up on firmware 4.2? I'm not sure what else to try!
I'm still having issues with using HomeLink when the car is backed up. The HomeLink works 90% of the time when the car is facing the garage door but less than 5% of the time when the car is being backed up to the garage, even when the rear of the car is nearly touching the garage door.
FWIW, I first stop when going past the driveway and press the Homelink button (I found if you don't stop, the door opens up a few inches and then stops). Then pull past the driveway and back in. This won't work if your driveway is long. If try the Homelink with the car already backed in, the success rate it low although pressing it multiple times usually works.
Thanks! I tried and tried to link homelink to my garage door opener with no avail. Once i opened the frunk, it worked quickly.I originally programmed my Roadster to operate 2 garage doors, but when I found out the convenience of not needing to go to a sub-menu, I deprogrammed one of them.
My frustration is that, given the small size and the location of the touchscreen, the old remote control on the visor was easier! I've noted elsewhere, the size of the button has to be larger and the location should be placed so its easy to press by feel/muscle memory without having to look for the location.
