Does anyone know if chademo adaptor needs the supercharging option unlocked?
Yes, it does. In US, the adaptor is $1,000 for cars with supercharging, and $2,900 for cars without.
Would it be possible to measure the temperature at the outlet on each of the pin (just point the laser at the pin location). I have a Non-Contact Infrared Thermometer with Laser Targeting in which I use. It will be interesting to see the temperature different when charging at 13A and 10A, and to see which pin is the hottest, after 2-3 hours of charging.
Isn't 32A the max we can get at a residential site in HK? So the 40A or 80A of the coming wall connector is just theoretical?
Any one heard this EVSE company? They have 62196 EVSE
http://www.cplus.com.hk/cpgroup.php?id=663&lang=1
It says their EVSE are in Disneyland and Shatin Racecourse
P.S. I usually charge at 13A, and the plug is usually hot to the touch after a few hours of charging. This time I dialled it down to 10A, and the plug wasn't even warm.
Hi Mark, so u can choose the current you want when you charge the Roadster, is there any minimum ? say can you dial it down to 8A or 8.5A?
I believe the 32A limit is for sockets and is a common limitation in EU also. 3-phase 3x32A 380VAC "Red Connector" is the largest plug and socket available at 21kW. Higher current devices like the HPWC must be hard wired, sometimes with nearby disconnect, depending local codes.Isn't 32A the max we can get at a residential site in HK? So the 40A or 80A of the coming wall connector is just theoretical?
The Roadster itself has fixed steps, and will let you dial down to 10A. Using the third-party OVMS system we can set 1A increments, but I think 10A is the lowest it will go to.
The language is very different from the UK version:Model S comes standard with an onboard charger and a variable current, single phase wall connector (10 amp – 40 amp). For charging on the go, Model S is compatible with public charging stations using an IEC 62196 standard port. Each provide charge rates up to 50 kilometers of range per hour of charge. For faster charge rates, equip your Model S with Dual Chargers and preorder an 80 amp wall connector. 80 amp wall connectors are under development and expect to ship in late 2014.
The main problem that I have with the language is that IEC 62196 encompasses Type-1 and Type-2. Type-1 is J1772 and Type-2 is the 3-phase compatible Mennekes style connector. In essence, they have still not cleared up whether the car will have 1-phase or 3-phase on-board chargers. On the one hand, the 40A and 80A numbers reflect commonality with the US on-board chargers because single charger and dual charger cars have those limits while the EU cars have 11kW and 22kW limits (16A x 3 and 32A x 3). On the other hand, if the car has single phase chargers, it makes no sense to put a Type-2 inlet on the car. It would make even less sense to put an IEC Type-1 inlet on the car when they could use the Tesla proprietary inlet like they decided to do in Japan. That inlet will be the first to support the Tesla CHAdeMO adapter.Model S comes with the necessary equipment to charge at home or on the road.
Charge at up to 30 miles per hour (32 amps)
- 11 kW onboard charger
- Mobile connector
- Standard household outlet adapter
- IEC Type 2-compatible charge port
- IEC 60309 230 volt adapter (Blue)
I confirmed Vmax's comments. Because I was ensured that HK Model S has 3-phase onboard charger, I added the twin charger because we have 3-phase in the garage.miimura, another quote from Linda's email from this morning:
The Model S is designed as a three phase, four pole AC induction motor already so while it is capable for 3 phase charging, we currently do not have a 3 phase EVSE available yet. Should there be a demand and once validation on it is complete, it is a possibility this will be introduced in the future.
My understanding of above statement is, the car will accept 3-phase charging, only Tesla doesn't have a 3-phase wallbox (yet). So 3-phase charging from a suitable wallbox (e.g. EV Power) should work. However I'm still clarifying with Tesla if my understanding of their email is correct.
The motor poles and phases are completely unrelated to charging and mentioning it in the same thought is questionable. If you accept "capable for 3 phase charging" as fact, that means that the only logical solution is to use the chargers and Type-2 vehicle inlet from the EU Model S vehicles. Any standard Type-2 EVSE should work, whether configured for 1-phase or 3-phase with any power circuit from 220V 10A (2.2kW) to 380V 32A (21kW). If they want to validate certain EVSE units, that is certainly their prerogative. Keep in mind that Type-2 EVSE are usually a Bring-Your-Own-Cable arrangement and each cable has a specific electrically coded current carrying capability.miimura, another quote from Linda's email from this morning:
