One of the reasons for our range anxiety is that we are faced with a change from what we have done before.
If we had been driving on electricity for 20 years and someone came up with the idea for a petro engine, we might also have anxiety about changing to gas as well.
Instead of simply plugging into our personal charging station and having a full tank every morning we would be told that we would need to fill our tanks with 20 gallons of a noxious, poison, combustion fluid. Warned not to breath the fumes get it on our skin or turn on the car inside our garage as it would quickly fill the air with death causing carbon monoxide. We would be forced to pay much more for this fuel than for electricity as it would be heavily taxed to pay for pet government projects.
The fueling stations would be located on some of the most convenient and expensive locations, right next to food stores, hospitals, churches and schools. Their large fuel underground fuel storage would often leaking dangerous chemicals and lead into our municipal ground waters. They would be huge fire hazard, so much so that the employees would not even pump the fuel into their customers cars, but demand that they pump their own fuel, and at their own risk.
The stations would not make their money from selling the fuel, but most of the profits would come from captive mini markets that would sell equally unhealthy and chemically laised fast food. Slurpies, carcogenic hot dogs, soda, beer, wine, cigarettes, energy drinks. All would be sold at premium prices over normal grocery stores, as they would have a captive audience wanting to kill some time, waiting for their tanks to be filled.
As a convenience they would also offer dirty restrooms often requiring a coin to open the door. They would offer you a key to open the door and attach the key to a heavy and bulky item so you would be sure to return it after use.
Every gas station would set their own prices. Often you would drive around, wasting gas and time, polluting as you go, to find the cheapest station. Then you would feel terrible when you pass a lower cost station just up the road.
All this would cost at least twice as much per mile as your faithful electric car.
Additional services would be required at regular intervals to keep these ICE vehicles operating. Every 5,000 miles you would need to change the lubricating engine oil, as it will have been contaminated by the fuel and metal parts rubbing off the engine internals. A special filter would be fitted to contain most of these metal parts, but it also would need to be changed as well. Be sure to put a little oil on your finger and rub it around the rubber sealing gasket so it will not leak oil all over your garage floor. Also be careful to remove the previously used gasket, because if you put the filter on with double gaskets, it again will leak all over your garage floor. Of course don't forget to replace your drain plug.
You will not be legally able to throw this used oil away, as it has become toxic waste due to being used inside the combustion engine. You will need to take it to a special store (don't spill a drop...quite a mess and impossible to clean out of your carpet).
Your sparking plugs will need to be replaced in regular intervals. Be sure to put a little gasket lub on the threads before installing or they will be impossible to remove when their time comes.
Running all these gas vehicles will cause the city air to become fouled. People will die early and get sick more often from the fumes. Wars will be fought between nations over control of these fuels. Innocent civilians will be killed and economies distroyed. Complex ecosystems will be destroyed from leaking pipelines and transport tanker ships. (Exon Valdez)
Can't imagine the anxiety that all this would cause to those used to running their vehicle on clean, economical electricity.
