SomeJoe7777
Marginally-Known Member
So we could try estimate if they'd work with our existing jacks; Could you share the height that your floor jack is able to drop to, and how much too high is that?
OK I just measured everything:
Height of my floor jack from ground to top surface of the jacking plate: 3.5 inches
Height to the top surface of the Jackpoint jack pad (with rubber shim) when sitting on top of the floor jack: 6.0 inches
Clearance under the Model 3 from the ground to the jack points: 5.5 inches
So my floor jack + jack pad combination is 0.5 inch too tall.
The Jackpoint low profile pads provide about 0.75 inches additional clearance, so with these I should be able to have a total height of 5.25" which should just fit.
