You are right, I am talking about range in miles, but so are you if you are using the trip meter. If you're truly just trying to measure energy usage, then you should also stick to pure energy measurements - either energy you had to "refill with" or apparently the CAN logger has this information.
Ref: https://www.evtripplanner.com/InterpretingTeslaModelSEnergyReadings.pdf
40:37 of the video show the 85kwh battery has 77.5 kwh usable. Pretty sure that you won't get any higher than that since they were setting the world record in distance that depleted the battery from 100% to below 0%.
What I can't wrap my head around though is how two cars, identical with identical software except for one having an "85 kWh" battery and one a "90 kWh" battery would estimate remaining or total capacity differently, relative to each other, so that the estimate on the "90" somehow ends up being the same or slightly lower than the "90"???
Two 90D cars can effectively give you a different battery charge percentage on the dashboard while having the actual same battery charge. It's because the percentage is software calculated from a bunch of approximations and can grow to be wrong over time (within bounds).
But the main point being that interpolating a portion of the battery discharge to 100% battery is a flawed method as a result of these approximations and the only way for me to really know my usable Kwh is to fill my car to 100% and drive it to 0%.
Well, actually if I fill it to 100% overnight and discharge it to let's say 20% I might get a slightly better number but the main point is that you need to start from 100% at least.
I agree with you, and have no data that shows that a 90D car driving from 100% to 0% isn't getting 81 or 82Kwh.I understand this but it has nothing to do with the fact that a large sample of "90" cars should show better total battery capacity than an large sample of "85" cars assuming the estimation/calculation methods are the same in both groups. The large sample should take care or variability within the groups.
There aren't that many 90D cars around. Did you find anyone who did a 100% to 0 ot 5% test?
Someone needs to do the testNo, sorry I don't. But I would love to have more conclusive data on this. You're not the first one with a "90 kWh" to bring up this
Let's calm downWell, how the heck are you supposed to figure that out? If it's an 85kWH pack, why wouldn't it be 85kWH? I'm not going to zero it and do a full recharge just to calculate this !
That's correct. That's what I was saying with internal resistance. You don't get full capacity from any battery if you're drawing a fair amount of current from them. So the way Tesla uses the cells, they are easily 4Kwh fewer than their marketing rating (and apparently, they may not quite have the right number so that the marketing rating really adds up to 85 or 90Kwh)Brand new packs show around 84 kWh available according to the diagnostic screens, however some of this is quickly lost as inefficiencies build up. The cells are generally less efficient at delivering their rated capacity when the load is appreciably increased. Thus, cells that were rated at 10 mA draw will invariably "lose" capacity as the average draw is increased to 100 mA.
How do you know they are very close?There seems to be little doubt in Australian samples that 90s get very close to the same capacity as 85s. This seems to invalidate the claimed 6% range gain and also price premium over 85 at the time. This appears to hold true with the same model specifications with similar mileage, settings and weather conditions. There are several online records being kept on these results, it would be great to see a definitive consolidated and statistical result on range differences between 85 and 90.
The point of having a large numbers of samples of each (85 and 90) is these issues cease to matter, since they can beDid you drive 2 of them from full to close to empty side by side?
Or are there numbers from different people taken in different conditions?
Did anyone drive a 90D from full to near empty and record the kwh used by the trip meter?
