Oops, sorry I haven’t replaced mine yet, just wanted to say that we probably won’t have to for a while if we drive responsibly.I’m at 13k miles since 8/18 with not a trace of wear. I am a gentle driver but drive a lot. No burn outs or launches that would scrub the tires. (LR, RWD). 43psi cold.
How do you feel about the difference between RE71R and the stock PS4S? Both of them have pretty good reputation. I also heard that Cup2 has very close durability to RE71R with better grip. Is that true?I'm about due to replace my tires and i'm not even at 5000 miles yet....
But these are RE-71R tires that have been to the track 5+ times
Cup 2 isn't popular with Autocross, where it seems that only 3rd car is NOT running on RE71R, because AX is populated by a bunch of cheap bastard lowlifes that eat tires left and right no matter the make, and RE71Rs prices are quite a bit cheaper?Cup 2 is going to be better than RE71R, which is better than PS4S. They're all in different categories really (streetable track, extreme summer, max summer - respectively). Cup 2's are pretty expensive though, probably would use those as a track only tire.
Or is there something beyond that that makes the RE71R better suited for high speed parking lot antics as opposed to circuits and streets?
AWD. I'm getting down to 2mm across all corners now, so will need to very soon. 13,000+ miles but also two Autocross days (ill advised, until I got alternate set), seems one TMPS might have been off or I missed the issue because had one tire get some over-inflation wear (now checking with a gauge directly), and front right toe was way out (from factory or too easily slipped out of line, don't think it took any serious bumps) leading to feathering on the inside. Toe now corrected but that spread some extra wear across three tires as I rotated, although most was on one of them.Has anyone had to replace their tires on their model 3 yet?
How many miles did you get on the first set and which version of the 3 do you have?
I've seen some Model 3s with Michelin tires and others with Continentals. Do certain cars come with certain tires?
Guilty as charged.Looks like it can vary quite a lot for different folks. This post should go hand in hand with what lifetime efficiency wh/mi people are getting
