Removing nose cone is a destructive process, more or less, depending on how skillful and careful one can be. The bottom row of clips actually are part of the cone and can be broken or worn (reportedly). Replacement cost of nose cone has not been listed yet(?).
If it is impacted with bugs & dust (my car!) it is really hard to do. This video uses 2 thick credit cards which is much more feasible than just one card. A coat hanger hook is the proper tool, but if it is kept IN your car then only useful to help out another MS. IF your nose cone is squeeky clean, also your hands, then you might be able to just grab & pull it off using NO tools.
FRUNK LATCH - Well kept secret. Eight MS enthusiasts did not know about this (myself included), even as just a concept. If I had half a clue (!) I could have rooted around and perhaps located it. No mystery about the LEVER - it is on the bottom edge of the dash exactly where just about every car made in recent memory has one - except it is on the PASSENGER SIDE. If the passenger window is open enough a wire coat hanger could be opened up into a hook to pull up on this lever, possibly. That is how close it is to the top of the window. Suzuki Sidekick/ GM Tracker also had the hood release on the passenger side - it was a tee handle inside the glove box.
Once inside the FRUNK you can simply remove the fuse box shroud (below the wipers) and then your 12 volt battery positive terminal is exposed. For a negative terminal you can clip onto any steel or aluminum chassis contact that is clean. You have to reach down a bit with the positive clamp to get to the battery terminal, but it should be doable.
There are so many possible MS FAILURE MODES that we really need to know about all MS features in order to be prepared. These videos are very helpful.
