stopcrazypp
"I don't know what Mobileye is doing, but that's not an HD map. They really claim to get 3cm localization without GPS using 10kB/km map data?"I was specifically responding to @mrkisskiss who was claiming 3cm localization with 10kB/km map size. Apparently the claim is actually 3-5cm lateral (in other words, 5cm), 10cm longitudinal... further discussion below
I'm talking about this part. You have said similar things about other HD maps, claiming they are not HD maps when they are, under commonly accepted definition (which is extremely broad).
30cm refers to 95% probability. RMS will be 15 cm. Yes, you are right, vehicle based GPS is already way better, but this news suggests further improvements in that front.Useless in urban environments, degraded when skies are overcast, probably degraded when operating at vehicle speeds, and anyway that 30cm that you get in goldilocks conditions is an order of magnitude off for lane localization. But vehicle-based GPS is already way better than phone GPS, at least in good conditions (better antennas, consistent orientation with respect to ground and heading).
If they only have landmarks every 200m, 3-5cm lateral/10cm longitudinal is aspirational and will only be achieved in goldilocks conditions (at least in the next couple of years). Real environments are punishing to systems like this. You could never build an L4 system that relied on this, and even an L3 system would need to have a very solid backup plan.
Also, going around a tight corner with +/- 10cm longitudinal accuracy is pretty iffy. In some cases you will be in the adjacent lane, or scraping the guardrail.
The GPS positioning and HD map is not going to be the primary factor, it'll only aid the vision system (at least this is how Tesla/Mobileye does it). It only has to be good enough to get it in the ball park (which lane is the right one to take, where the approximate location of the traffic light/sign is etc) and the vision system will do the rest (even with no lane lines, there are contextual ways to tell where it is located; that's how we do it with our own brains). The inertial based (and similar) systems will also help in areas of poor or no signal.
For example, even though your GPS unit does not give you accurate information on lane positioning, you are in no danger of being in the adjacent lane or scraping a guard rail. Where more accurate positioning is useful is for example telling which lane you are in (leftmost/rightmost: useful for determining turn lanes or exit lanes).
