A quick follow-up on the
"which Continental radar" discussion...
So we already know that Tesla pulls not one, but
two CAN outputs from the Conti radar. Looking at the Model X wiring diagram, these channels are called "CAN" (+ and -) and "CAN2" (+ and -). In the Model S wiring diagram they're called "CAN Primary" and "CAN Secondary". Notice that Tesla does not use the word "redundant" for the second CAN-output, but "2" or "Secondary". In contrast, Tesla does use the word "redundant" on some other wiring connections, for example "Batt Redundant" for the redundant (duh!) Power Steering ECU power supply. (Of course these semantics don't rule out the possibility that the secondary CAN is in fact for redundancy, but it might indicate that it's for something else. Which I'll come back to...)
Anyway, both CAN channels are on the same physical connector (the radar only has one), and they both go directly to the glove box (AP2.5ECU).
Since we now have our
first actual picture of the radar, it's possible to compare form factor with available Continental radar types. I have, and the one that stands out to me is the
ARS 404-21. Among all Conti radars, this one is the closest match, I think. The "giveaway" is the small hole in the upper left corner of the radar, plus the indents in the "upper stage" of the radar. What do you think?
You'll notice that the connector seems to be different. And it is. The ARS404-21 comes standard with a Hirschmann connector, while Tesla uses Sumitomo. So Tesla's radar could be somewhat custom wrt. to connector and/or wiring. And that's where the two CAN channels come in:
According to Continental's
datasheet and
this very informative description, ARS404-21 apparently comes standard with only
one CAN output.
But, the Hirschmann 6-pin connector does have two pins for “CAN” that are “N.C.” – i.e. “Not Connected” (not in use). Tesla's Sumitomo-connector is also 6 pin, with GND, IGN, CAN+, CAN-, CAN2+, CAN2-.
Now the interesting part is that the ARS404-21 has software-adjustable range resolution and max range, and switches between Near and Far range:
Another benefit of the radar principle is a software adjustable range resolution and maximum distance. The sensor is capable to setting its range resolution from 1m and more up to 0.25 m, which can be done externally via CAN interface.
Selecting near range and far range scan is done via digital beam forming.
Furthermore, the radar:
can be set or changed by the customer for different functionality via CAN bus:
a. Sensitivity from low to high in several steps.
b. Objects (OB) or Cluster (CL)
Could it be that the two different CAN-outputs are for Near and Far range detection? (Custom for Tesla?)
