Are you able to get up into the attic under the panels and inspect where the screws missed rafters?No I was not present. I was on duty for 24 hours so I couldn't be there, also a high resolution stud finder would have worked. Now I will have to have the panel mounts inspected to make sure they are all drilled into the rafters. I live in a hurricane zone
The space is too tight for me, the inspector is coming tomorrow with someone that can get in the atticAre you able to get up into the attic under the panels and inspect where the screws missed rafters?
Hope he/she is old enoughThe space is too tight for me, the inspector is coming tomorrow with someone that can get in the attic
Update…. I had 2 different roofers take a look. One also inspected the attic and says there is more than one leak. He took video of the leak where the installers drilled through the decking and tried to reseal it. He temporarily sealed to holes by lifting the shingles and patching the holes from underneath and on top of the shingles. I got estimates from both for repairing the leaks. I have one more roofer coming by later this week.
Are you 100% positive that Tesla did it during the solar install? I ask because one of the patched holes you showed a picture of looked close to what looked like a satellite dish mount...
And as far as timing every roof doesn't leak until it does. It could be that the extra walking around during the solar install caused a prior, poor, patch to fail.
How old is that roof? It doesn't look young. Even though my roof had some years left I had a new roof installed before installation.
Also my installer has absolutely no flanges exposed, everything is under the panels. Very tidy.
Not depending on any "goop" and then the solar panels themselves add another layer of protection.
Yes, but, rain still runs down the roof under the panels from the top. or wind driven at times from other sides.How old is that roof? It doesn't look young. Even though my roof had some years left I had a new roof installed before installation.
My roof is 10 years old, I am in Florida so the sun is pretty tough on roofing.
Regarding the feet, what do your plans say? Tesla seems to almost always use Zep Mighty Hook these days which leaves the shingle surface intact. Weird they didn’t in your case.
Exactly.
Mine was about 10 years old too, I ditched it. Insane to do "new work" on brittle old shingles. You want soft pliable self sealing new shingles.
That was problem #1.
Most installers will remove panels for work that needs to be done for free and reinstall. Just get them removed and have a roofer fix it.
Seems like drilling lots of extra holes would cause leaks in new shingles too.
I noticed all the flashing. Yes, you got a great installation. The other install with all the holes with plugs visible did not get such treatment.Not much wind will get under there. Snow won't get under there. No sun. Not even much rain because there isn't much roof left in my case.
Sun is the killer.
They have very large flashing for each mount/bolt and it was a new roof so it will seal to bottom shingle it tucked under. Super tight job. Not a single wire or conduit exposed directly or visible. Not one dab of caulking exposed [even without the solar panels] (which never lasts anyway).
