Was there some nonesense that it needed to be 100% charge to update the UMC?? I could be making that up……
It may have been just after a charge is complete.
1. It's 2022.8.2Requirements for 10A and 15A charging are:
1. Minimum software version 2021.12.25.7
2. Tails that have "10A" and/or "15A" written on them
3. Charging completion (eg. If car is at 60%, set it to 61% and let it complete) and leave plugged into car.
4. Power-cycle of UMC after update.
(possibly) 5. Connected to Wi-Fi.
We should all accept that doing the happy dance is an undocumented feature.Lol the dance worked!
It went to 10a this morning. Tesla needs to add it to the manual
Haha I love this! Good to know!Lol the dance worked!
So what was the general consensus of what the most ideal/cost effective home charging is?
Really appreciate you sending that thank you.A great write-up:
I use the UMC / 32A tail option.
This is definitely not required, I have updated two UMCs without WiFi connected. The UMC update is fully contained within the updated car software - if your car software is new enough, it will update the UMC (it can also update HPWCs as well the same way!).(possibly) 5. Connected to Wi-Fi.
You should try to unplug the car for 5 or so minutes and then replug. Restart the app and then it should be showing the increased amps. This is on the proviso that car has reached the set SOC and has had a chance to sleep directly after reaching the set SOC This should allow the UMC to update. That worked for me.I have had mine plugged in each night and finish charging and left overnight.
Still only showing me 8A as highest option.
I’ve tried doing the happy dance.
Fingers crossed tonight it decides to update itself!
Do you lock your car when you leave it overnight?I have had mine plugged in each night and finish charging and left overnight.
Yes I do.Do you lock your car when you leave it overnight?
No, I was thinking the other way around - when I was testing it, locking the car seemed to kick the update off sooner, but it might have just been coincidence.Yes I do.
Should I not lock it and see if that changes anything?
I noticed on the app that the interior temperature is 38°
I’ve turned on the a/c to cool it down
Hi folks first time posting here I am from nz and ordered a MY now trying to sort out home charging
Wondering if I can just get an electrician to install a 15A socket without the need of expensive type b rcd?
In nz my daily usage around 60km but will need to turn on sentry mode in car park.
