I don't think that's the case: multiple receptacles on 240V circuitThe short answer is "no, each outlet requires its own wiring and its own breaker".
Doesn't the "fastened in place" requirement only apply in living spaces? Garages aren't considered living spaces.NEC 210.23 says one outlet per breaker at the levels you are asking about
LOL, we're back to this part of the NEC again. NEC requires GFCI breakers on outlets "installed for the purpose of charging EVs" but does not ban outlets that were installed for other purposes from later being used to charge EVs without meeting 625.40. So you could have easily installed the outlets for something else and then changed your mind as far as what you wanted to use them for., or perhaps more definitively:
625.40 Electric Vehicle Branch Circuit.
Each outlet installed for the purpose of charging electric vehicles shall be supplied by an individual branch circuit. Each circuit shall have no other outlets.
The install instructions are clear that they want each wall connector in a power sharing group to have it's own branch circuit. This can be done in a subpanel, or small load center if you like, but they both need their own breaker.
People normalize electricity because they "just plug it in and it works" and forget about the fact that if its not done properly, you can literally burn your house down. Since most charging is done at night, and EV charging is the single biggest continuous load a home is likely to have, its not the time to be messing around with "it should, if we just".I understand if you run both chargers at 40 amp, it'll overload the breaker. But if you just run 24amp for each charger, that should be fine from a load standpoint?
I like this idea! I already bought a Maxi charger but $300 more get you two ports!! The renewed charger tax credit will probably help with this decision!People normalize electricity because they "just plug it in and it works" and forget about the fact that if its not done properly, you can literally burn your house down. Since most charging is done at night, and EV charging is the single biggest continuous load a home is likely to have, its not the time to be messing around with "it should, if we just".
Dont plan on power sharing 2 charging EVs though a 14-50 outlet. If you want to do power sharing, get wall connectors that are setup for that purpose. The simplest way I am aware of to do that is to get an evse with 2 charging wands in it. Run one connection, wire in the EVSE and it can share the loads automatically (and code compliant).
Something like this:
Where's the outlet? I believe you can get a tax credit of up to $1000 for EV charging equipment and installation so if you need another outlet on its own circuit, you can just pay an electrician to do it and get credit for it. The EV Charger Federal Tax Credit is BackI like this idea! I already bought a Maxi charger but $300 more get you two ports!! The renewed charger tax credit will probably help with this decision!
Yes, after tax credit the extra EVSE cable is about $200.I like this idea! I already bought a Maxi charger but $300 more get you two ports!! The renewed charger tax credit will probably help with this decision!
How so? Your mean constantly unplugging the adapter? I plan on leaving it on permanently and get an extra one to carry in the car. My MY it's being picked up next Fri.Yes, after tax credit the extra EVSE cable is about $200.
But here you get what you pay for: The Grizzl-e is power sharing 40 Amps. If that is all your branch circuit is rated for, it makes good sense.
Do figure though that the Grizzl-e is a J1772. You give up some Tesla convenience
On some EVSEs you can do this, and on others, it's more difficult. My ChargePoint Home (which I use to charge my PHEV) has a dock for the charging handle on the unit itself. The handle will not latch to the dock with the J1772 adapter on the end.How so? Your mean constantly unplugging the adapter? I plan on leaving it on permanently and get an extra one to carry in the car. My MY it's being picked up next Fri.
I don't need to charge super fast. 100 miles per night a enough for my commute. My wife's future plug in obviously has shorter EV range. And 40 miles would be enough for her.Yes, after tax credit the extra EVSE cable is about $200.
In the garage. Does this matter for the tax credit?Where's the outlet? I believe you can get a tax credit of up to $1000 for EV charging equipment and installation so if you need another outlet on its own circuit, you can just pay an electrician to do it and get credit for it. The EV Charger Federal Tax Credit is Back
I mean, where's the outlet in relation to the vehicles in your garage? If you have two stalls and it's all the way on one side of the garage (such that you'd have to pull the cable across the path of another vehicle to reach the vehicle in the second stall), then it might not be so convenient to get the 2 connector EVSE. It's probably better to just install another outlet on its own circuit and get an entirely separate EVSE for the second outlet. You may be able to get yet another tax credit for that as long as you do it in a different year than you did the first one (would have to check tax law on that to be sure though).In the garage. Does this matter for the tax credit?
probably a dumb question and I'm obviously not an electrician nor am I doing this work myself. But just trying to understand and see what I can do to future proof. Thanks!
