If u have original 85 pack then no, fuse is on top. Newer packs have fuse on bottom
Normally if 12v is bad ur car will never cut off anything during drive because its providing its own 12v when contractors are closed (kinda like alternator on ICE)
Unless 12v pyro blew, did u ck it?.. or fireman's loop broken..
or HV pack fuse blew (i believe u might have old sand type that blows over time), although u should have diff codes...
u have other codes which could just be bad ground... or lack of 12v due to pyro.
up in this thread it was mentioned that u might have to reset some of these codes to go away...
get multimeter n start checking things
I just find it odd that I got these issues after buying the new OEM Tesla 12v battery. Even though the old one dies out, it worked when it was trickle charged.
Things I did so far for Diagnostics are:
- checked continuity on all of the battery fuses (on top of battery) including the 12v pyro fuse. All passed continuity.
- removed the whole frunk assembly and checked for poor grounding, that also passed continuity but I took the nut and bolt out to clean anyways.
- checked the 10A contactor fuse and ALL other fuses in the frunk (4 fuse boxes including the battery top) all passed continuity
- checked continuity on the fireman's loop, passed
When I get in the car I get the following codes:
- BMS_w062
- BMS_w033
- BMS_f062
- BMS_f033
- GTW_157_LowPowerSupportFault
- GTW_w405_12VNotSupported
The old battery I has was a "red top", the new one is a "Grey top". I told Tesla to configure the battery to the new one, they claimed to do that OTA. Still no luck.
When I press the brake the car actually "Starts". But as soon as I try to put it in Drive or Reverse I get the following error:
- DI_u014_NotOkToStartDrive
Description: Drive Inverter User Alert: 12 V supply not sufficient for drive
A few weeks back with the old battery (when it was failing but i kept trickle charging it) I had the following error come up:
- BMS_w010_SW_Neg_Contactor_Drive
Description: Unexpected current level through negative contactor drive circuit
- BMS_w009_SW_Pos_Contactor_Drive
Description: Unexpected current level through positive contactor drive circuit
These went away after trickle charging the 12v.
At the point I'm running out of options.
- Can it be the 12V Supply (30A) fuse in the DCDC Converter ( I will test this next for continuity)
- Can it be a defective battery they sold me?
- Can it be a failed HV component such as the Battery Heater?
