I would love to see an internal wiring diagram from the HV battery internals but I think you need to trace the 12V and if it goes to BMS yes it could be faulty. It's not something that goes bad often.
The fault literally says lost contactor power while driving and will be gone when the issue is restored
BMS_f033_SW_Crash
The Battery Management System (BMS) will trigger this alert when it senses a loss of contactor power while the contactors are closed. The BMS assumes that it could be because the pyro fuse on the contactor power supply signal blew during a crash.
This may trigger while a vehicle is in Service and the contactor power supply loop has been pulled.
BMS_f062_SW_Ctr_Pwr_Supply
The Battery Management System (BMS) has detected that there is a power supply issue with the contactor.
Yes, up to this point I will say I have traced the 12v supply all the way up to the battery and all check out. I am looking to book an appointment with a shop 600km away from Toronto since Toronto does not have any EV shops to have them change the BMS board and contactors. I will update if it gets solved. As for the codes, here are the descriptions I got from the articles, also I will include a summary of all of the diagnostics I have done thus far in hope to come to a final solution should this happen to anyone else.
Summary
INCIDENT ONE
February 4, 2024: I supercharged my car and drove heading home, initially a few DTCs showed up and I lost regenerative braking on my car (intermittently coming on and off) on the drive home. The initial codes that came up were:
- BMS_w010_SW_Neg_Contactor_Drive
- User Text: Service is required
- Schedule service now
- Description: unexpected current level through negative contactor drive circuit
- Article Description:
- BMS_f010_SW_Neg_Contactor_Drive (I did not get the f010 code, but good reference)
- There is an issue with the negative contactor drive circuit.
- BMS_w009_SW_Pos_Contactor_Drive
- Description: unexpected current level through positive contactor drive circuit
- BMS_f009_SW_Pos_Contactor_Drive (I did not get the f009 code, but good reference)
- There is an issue with the positive contactor drive circuit.
- BMS_u008_limpMode
- User Text: Acceleration and top speed reduced
- Performance may be restored on next drive
- BMS_u008_limpMode
- The vehicle has entered limp mode.
- BMS_w141_SW_Pwr_Supply_low
- User Text: Power reduced – Unable to charge
- Service is Required
- Description: BMS input voltage too low
- BMS_w141_SW_12V_Pwr_Supply_Low
- The Battery Management System (BMS) has detected that there is an issue with the 12V power supply to the contactors.
Resolution (at the time): I charged the 12v battery and ALL warnings went away and I was able to drive normally without any issues for a week.
INCIDENT TWO
February 12, 2024: Warnings starting showing up again and the 12v battery kept on dying. I was not home. Car was parked at a shopping plaza 5 km away from home. I boosted the car with a spare battery enough to start and drive it home with warning (but still able to drive). When I got home, I charged the 12v battery. The next day I changed the 12V battery with an OEM 12v from Tesla. After changing the battery and attempting to drive the following error codes showed up on my car:
- DI_u014_NotOKToStartDrive
- User Text: Unable to drive
- Voltage supply too low
- Description: Drive Inverter User Alert” 12v supply not sufficient for drive
DI_u014_notOkToStartDrive
The Drive Inverter has detected that the 12V battery is not being adequately supported by the vehicle, which means the vehicle might lose 12V power while being driven.
To set this condition, one of the following must occur:
- The Intelligent Battery Sensor (IBS) current is < 0A.
- The IBS voltage is < 12.9V.
- The GTW_12VState signal is in one of the following:
- DCDC_NOT_ENABLING
- 12V_NOT_SUPPORTED
- BMS_MIA
- FAULT_WAKE
- DCDC_RETRY
- GTW_w157_lowVoltageSupportFault
- Vehicle systems shutting down
- There has been an issue in providing support to the low voltage (LV) bus, and the voltage has dropped below the target. This can be caused by:
- Wiring issues between the DCDC and rest of vehicle on LV harness (B+ or ground).
- Loose 12V battery positive or negative connections at either end of the harness.
- No LV support provided due to low Battery Management System (BMS) State of Charge (SOC).
- No LV support provided due to BMS issues.
- No LV support provided due to DCDC issues.
- No LV support provided due to E-fuse DCDC fuse tripped.
- DCDC is not enabled by the BMS or E-fuse.
- Controller area network (CAN) bus issues with PT or BDY.
- This alert does not mean the 12V battery is bad. It means the vehicle is not adequately supporting the 12V battery and LV system.
- GTW_w405_12VNotSupported
- User Text: Electrical System Power reduced
- Vehicle may shutdown unexpectedly
- BMS_w062_SW_Ctr_Pwr_Supply
- PULL OVER SAFELY
- Description: Contactor input voltage dropped below limit threshold
- BMS_f062_SW_Ctr_Pwr_Supply
- PULL OVER SAFELY
- The Battery Management System (BMS) has detected that there is a power supply issue with the contactor.
- BMS_w033_SW_Crash
- PULL OVER SAFELY
- Description: Contactor power dropped while in drive.
- BMS_f033_SW_Crash
- PULL OVER SAFELY
- BMS_f033_SW_Crash
- The Battery Management System (BMS) will trigger this alert when it senses a loss of contactor power while the contactors are closed. The BMS assumes that it could be because the pyro fuse on the contactor power supply signal blew during a crash.
- This may trigger while a vehicle is in Service and the contactor power supply loop has been pulled.
DIAGNOSTICS PERFORMED
- Checked all fuses
- Checked all ground points for corrosion
- Changed 12v Battery
- Removed and took apart DC-DC converter. Inspected all fuses including internal DC-DC fuse (continuity pass)
- Performed 12v supply trace (and continuity) on contactor line on:
- F93 (continuity pass)
- X551, F29 (Continuity pass)
- X535, Pin 2 and Pin 4 (12v Pass)
- X950, Pin 6 (12v Pass)
- Dropped the battery pack: X036, Pin 5 (12v Pass)
- Dropped the Battery pack: X035, Pin 5 (12v Pass)
- Performed 12 supply trace (and continuity) on BMS line
- Continuity on F53
- X950, Pin 7 (12v Pass)
- Dropped the battery pack: X036, Pin 2 (12v Pass)
- Dropped the Battery pack: X035, Pin 2 (12v Pass)
- Performed Ground Check:
- Dropped the Battery pack: X035, Pin 12 & 8 (Continuity Pass)
- Dropped the Battery pack: X036, Pin 12 & 8 (Continuity Pass)
On March 31, 2024, the battery pack was dropped for further inspection of X036 and X035 to the pack. All inspections of the LV Rapid Mate connectors passed with respect to the contactor line. Battery pack was re-installed back into the vehicle. Unfortunately, due to time constraints from the shop, the battery pack was rushed and installed (missing one screw) and the
LV Rapid Mate connector was NOT seated properly when re-installed. As a result, now there are a number of additional errors that show on the dash.
Please refer to the initial error log above when looking at the logs for the actual issue, the additional errors that are now present indicate there is no communication to the pack at all since the rapid mate connector is not properly seated (except for showing the battery range left on the dashboard, 250km left).
