Installed adjustable rear camber links to reduce rear tire wear
Discussion in 'Model S: Driving Dynamics' started by artsci, Nov 20, 2014.
  1. artsci
    artsci Sponsor
    Timonium, Maryland
    Today I had SUPRKAR's adjustable rear camber links (see post #502) installed on my car. The installation took about 3 hours but it was well worth it as the setting are perfect for minimizing rear tire wear: -1.00 camber and 0.18 toe. Without the adjustable links the -1.00 camber setting is near impossible. The work was done by Jeff Wise of Wise Automotive in Timonium, MD. The guy's a perfectionist -- he would not stop until he got the specs spot on. He removed the aerodynamic panels under the rear axle to provide better access to the links as he was making the settings.
    I've driven about 15 miles since the installation over familiar routes and the change in handling is not substantial. The adjustable links are a work of art.
    Here's a shot of it installed.
    And the setup equipment.
    Thanks to lolachampcar for all of the work he's done to make this possible. And to SUPRKAR for having the adjustable links made.
  2. schneiderjohn
    schneiderjohn Member
    Atlanta, GA
    Very cool! If you don't mind, could you give us a ballpark figure on what something like this might run?
  3. Denarius
    Denarius Active Member
    Utah
    I'm very interested in this, but waiting to see if there are any changes in the P85D setup.
  4. artsci
    artsci Sponsor
    Timonium, Maryland
    With the links and installation costs, about $1,100. Just in saved rear tire costs alone it should pay for itself in no more than two years.
  5. schneiderjohn
    Atlanta, GA
    Wow! That's not too bad! I do wonder what the benefit will be on D-models, considering the expected decrease in rear tire wear. Perhaps still beneficial, but will likely take longer to pay for itself.
  6. jerry33
    Texas
    Unless they have changed the possible alignment settings, it should provide the same benefits. (resistance to the shoulder wear during turns, which isn't the same as the reduced wear that the D provides).
  7. hbombdaddy
    hbombdaddy Member
    cincinnati ohio
    Rick:
    Anything different: for install of links, and settings, for p85+ vs p85 staggered 21 vs regular 21's
    your buddy howard in cincinnati
    ps LOVE YOUR FRONT CAMERA!!!
  8. artsci
    artsci Sponsor
    Timonium, Maryland
    No sure about the P85+, which may have different settings.
  9. zwede
    zwede 2013 P85+
    Plano, TX
    P85+ has the same rear suspension and alignment specs as the P85 (w/ air).
  10. artsci
    artsci Sponsor
    Timonium, Maryland
    Thanks Howard. Ironically, when I had the MobileEye System installed the installer managed to disable my front camera. The usual solutions did not work so I probably have to replace all of the cables to get it to work.
  11. Jason Bloomberg
    Cheyenne, WY
    Now that you have had them for a while how do you like them?
    Thank you.
  12. artsci
    artsci Sponsor
    Timonium, Maryland
    This is one of the best cost-saving mods I've made, as rear tire replacement has been substantially reduced. So it was worth every penny.
  13. BigCity
    BigCity Member
    Avon, IN
    Are the links even available any more? Would love them on my P100D, otherwise I guess I'll start driving in HIGH or VERY HIGH on my unplugged brackets for highway driving to avoid ruining my new set of tires in 5k miles like my last set?
  14. artsci
    artsci Sponsor
    Timonium, Maryland
    I think they are, but contact BBC Speed And Machine to determine.
  15. BigCity
    BigCity Member
    Avon, IN
    Thanks! I'll reach out to them and see what they say. Are they difficult to install, guessing any good alignment shop would be able to handle it? Only caveats being dealing with Tesla if anything came up.
  16. rknp85plus
    rknp85plus Member
    Houston
    So does the UP brackets and driving at a higher corrected some of the negative camber? Can you tell any difference in the tire wear?
  17. BigCity
    BigCity Member
    Avon, IN
    Brackets would make it worse since they lower the air ride set points. That's why I'm interested in finding a way to correct the rear camber, which sounds like a one off custom made piece. I went through a set of hankooks in the rear in 5-7k miles.
  18. artsci
    artsci Sponsor
    Timonium, Maryland
    I had installation done by a local shop that I trust. The rear diffuser has to be taken off to provide better access, so I lift was needed, and an alignment has to be done after installation.
  19. Naonak
    Naonak Member
    Kansas
    BBC Speed and Machine still sell them. $1235 shipped.
    They are super easy to install. Just remove the rear wheels and two large bolts (19mm if I recall) and one 7mm bolt will remove them, then replace.
    You'll need to immediately get an alignment though, as your camber is going to be seriously off after installing these. I tried to eyeball it and got dead on with one side, but was really off on the other side.
    Takes about 20 minutes a side if you know what you're doing. Otherwise, budget about 1.5 hours.
  20. BigCity
    BigCity Member
    Avon, IN
    Awesome thanks for the reply will make a call tomorrow.
