I was planning to try to use Nyland's DIY (speaker foam + the sun screen), but I have an April-2016 Model S and the Tesla store states that the pano sun screens only fit pre-2015 date cars![]()
considering all the efforts being made to negate the panoroof, would you suggest not getting a panoroof?Heat rises, that's why trapping heat at the roof helps. in the winter the sun is low, so letting sun in side windows is good, but tinted top pano lets in hardly any solar heat, may as well block it, no harm And the pano is inches from the head, which is where you lose a lot of body heat.. all good reason for insulating the roof in the winter. Speaker grill foam is not a good choice, there's hardly any thermal mass or R value, very airy.. and it's not reflective.
I used foil bubble wrap insulation cut to fit. You can buy big rolls of the stuff at home depot. Last year mine kinda sagged in the middle so I will add a couple suction cups, good idea, thanks!
Makes a difference! I had a rear piece installed and overnight frost formed on that glass but over the front seats where no insulation was in place yet - frost free - telling me heat was leaving there moreso than being insulated..
Love the Pano!! helps make the car feel airy and spacious.
you need to localize where the noise is coming from and then once localized check that the window gaskets are properly set, the insulation more than likely would not stop any wind noisesWhat are you guys doing to decrease wind noise? I can't tell if mine is from the pano roof or somewhere else.
I had some wind noise from the small triangle window when I first received the car, but the SC fixed it up and haven't had any since. Note that sometimes tire noise sounds like wind noise.What are you guys doing to decrease wind noise? I can't tell if mine is from the pano roof or somewhere else.
The real way to find wind noise is to get some microphones designed for finding automotive noises. You place them in various locations and then refine the placement until you find the spot(s) where the noise is coming from.
