Integration with Google Home / Google Assistant - Now available for general use
Discussion in 'Model S: User Interface' started by Gol4, Jun 7, 2017.
  1. Gol4
    Gol4 Member
    San Jose, CA
    A new version of this app has been deployed. It supports Window Venting, Charge Port Control and Homelink Control.
    New commands:
    vent windows
    close windows
    open charge port
    close charge port
    trigger homelink
    activate homelink
  2. MasterT
    MasterT Member
    Home
    Yeahh!!!! Closing windows works from either venting or full opened position (2017 AP2 MCU1 X) - Thank you!
  3. MasterT
    MasterT Member
    Home
    Is it possible to add these new commands to the first page of this thread? Would be helpful for newcomers.
  4. Gol4
    Gol4 Member
    San Jose, CA
    I don't see a way of doing that. Is it possible to edit old posts?
  5. DopeGhoti
    DopeGhoti Active Member
    Phoenix, AZ
    Not after a very short "time to fix some typos" window. I think the only exception to that is if the OP is a "Wiki" post, but I'm not certain about the details about doing that, or whether a normal OP can be converted into one.
  6. Spencer L.
    Spencer L. New Member
    London, England
    I see that your Amazon
    Hi Gol4, I see that your Amazon Alexa skill is now called My Tesla and is Tesla exclusive where as EV Car is now going to work with all other brands of EV, is that correct? Is this going to happen to the Google Home ‘action’ or whatever a Google call skills? Thank you!
  7. Gol4
    Gol4 Member
    San Jose, CA
    Right now Google Home action and the two Alexa skills (EV Car and My Tesla) all do the exact same thing. The original idea was to have EV car branch off to handle other connected vehicles but I have no immediate plans to do that right now.
  8. JHerbY2K
    JHerbY2K Member
    Calgary, Canada
    I get "Isn't supported on this device". Managed to link it via the web though... just can't seem to use it. Is this an iPhone issue or a Canada issue?
    edit: nevermind, works via the assistant app not the google home app. Still trying to understand how this thing works!
  9. MasterchiefTS
    MasterchiefTS Member
    Italy
    Is there something for Cortana?
  10. fallen888
    fallen888 Participant
    Newtown, PA
    It's ok, but not great.. I tried to switch cars and it thinks my S is a 3. I tried to open my car and opened the trunk instead. o_O
  11. thegruf
    thegruf Active Member
    indeterminate
    a Mod can probably do this if you ask.
  12. thegruf
    indeterminate
    @Gol4 - thanks again for this work - better still is there a way you can get Google Assistant to list the available commands on the phone?
    Sure would help my iffy memory. Thanks.
  13. thegruf
    indeterminate
    #273 thegruf, Dec 31, 2019
    for those less familiar with Google Assistant and looking to change the name of "EV car" - Google has now moved on from "Shortcuts" to "Routines"
    goto your Google Home app; tap on your user icon (Letter in Circle) top right of screen
    tap on "Assistant settings" from the menu
    tap on Assistant
    scroll down to Routines
    tap on "+ Add a Routine"
    Tap on "Add Commands (required) >"
    example you could change
    "EV Car" to "your cars name"
    or add a routine "Get car ready" with a sequence of commands to warm it up, set the seat temps, open the garage door etc
    .. have fun
  14. Gol4
    Gol4 Member
    San Jose, CA
    You can say "Ask EV Car for help" . That will list out most basic commands you use.
    This direct URL to the Actions Directory Listing display all commands: https://assistant.google.com/services/a/uid/000000196c7e079e?hl=en
  15. webpatrick
    webpatrick New Member
    Netherlands
    The Action Directory Listing doesn't show the latest added commands, like trunk, window, chargeport and homelink features.
  16. MikeeUK
    MikeeUK Member
    UK
    Great app! I have a number of routines setup now :)
    Is "unlock charge port" also included? I tried the command and it just says "charging cable connected".
    I would be really useful to have this as I find it a pain to get my phone out to unlock when removing my charger cable. Thanks.
  17. Gol4
    Gol4 Member
    San Jose, CA
    You can say "open charge port". If a cable is plugged in, it will unlock the port.
  18. FMinMI
    FMinMI Member
    Mid Michigan
    Just set up a bunch of custom routines. Works great! Is there a way to open/close sunroof? How about turn seats on/off besides using the climate on/off option?
    Thanks for the great interface to Google Home!
  19. RTPEV
    RTPEV Member
    Durham, NC
    Wondering if there is any update on this issue? EV Car is great...if the car is awake...otherwise I have to get into the Tesla app to wake my car first, which defeats the purpose of what I am trying to do: "Okay Google, get ready to leave" would give me state of charge and turn on HVAC. I tried issuing a dummy command at the beginning, then go off and do some extra stuff like tell me the weather, tell me about my commute, tell me a joke and then try the range and HVAC commands, but the car is still not awake, even though from the Tesla app the car wakes up in just a few seconds.
    Does the count to 100 trick actually work? Does it eventually wake up on its own?
    Architecturally, can EV Car add a command to "wake up my car" and then keep re-checking the car for wake status in a loop (until a really large number of attempts were unsuccessful)?
    Is this actually a Tesla API bug? I wonder why the app works well, but 3rd party apps wouldn't. I thought 3rd party apps were basically just copying the Tesla app API calls.
    Not to sound like a whiner on my first post in this thread, so I'll close with my thanks for a really great job with this. When the car is awake and EV Car works, it is marvelous. So thank you!
  20. Pagemakers
    Pagemakers Member
    Manchester UK
    1. Can you turn seat heating on/off?
    2. How about sending a destination to EV Car? @Navigate to Leeds Supercharger” for example.
