Glamisduner
In other words, no?That is like asking if a car is fast enough
Unless you’re planning on drinking out of your windshield wipers, the main reason for not using water is you don’t want it to freeze and cause your lines to crack.
Caution: Do not add formulated washer
fluids that contain water repellent or bug
wash. These fluids can cause streaking,
smearing, and squeaking or other noises.
That's good life advice in general. Don't use Rain-X, don't use the bug nonsense. Get regular washer fluid. It's alcohol (methanol usually) and water with some blue dye. That's it. Adding anything else is going to make your windshield a total mess, it'll haze over, it'll smear, and you'll have a bad time. Rain-X is *sugar* anyway.
Get yourself some good silicone wipers, clean your windshield with glass cleaner regularly (once a month at least), and everything will be just fine.
@tomc603 what brand of windshield washer fluid do you use?
I've been making my own for years. A few drops of dish soap (I mean drops, like 3 - 5) and a couple tablespoons of Windex in two quarts of water.
is there an easy way to drain the washer fluid?
my PPF installer suggested I drain it as it could contain ammonia and that will cause the PPF to rainbow.
It does make you wonder what these "other noises" are that they found during their testing are so dreadful they wouldn't even dare to describe them.
That's why I use barely any. I've never had a problem with the washer system in my other cars. I do know that using a lot of dish soap or vinegar will definitely wreck the system.Windex contains ammonia which can cause problems with rubber seals after repeated use. Lots of dish soaps contain additives that will build up on your windshield and cause seriously streaking, and others still have moisturizers for skin which your car doesn't need. Just methanol and water.
If my chemistry serves, the 3rd inactivates the others.1 drop of Dawn Ultra dish soap
1 drop of Ultra-Palmolive Antibacterial
1 drop of Spa-Guard Anti-Foam (made by BioGuard) (a one pint bottle will last for a lifetime)
Be careful doing this, Isopropyl Alcohol will react against certain forms of plastic and rubber and aluminum and the hoses are rubber. Don't ask me how I know It worked great for a couple months in the winter!!!I use distilled water from Walmart in the summer, and a mix of that with Isopropanol (~ 50%, depending on temps) in the winter. Most winter fluids for sale use methanol to raise the freezing point but I avoid it due to toxicity.
Try not to use Windex! it has wax in it and with continued use will make the window cleaning harder and cause fogging.
This works:
2 QTS distilled water
5 pints of 91% Isopropyl Alcohol (Walmart)
mix in a 1 gallon container and label
shake the gallon container to mix add another drop of Anti-Foam if the bubbles do not disperse.
