IMO, I only think it is unfair to future 75D buyers. They will have to go to Tesla to find out if a 2017 car they are thinking of buying has been (or can be) uncorked.
For me, if I had the choice between the 90D I collected in March or an uncorked 75D (with 85 battery), then the 75D would have got the sale, saving me a few $$ in the process. But I didn't have that choice and am happy with the 90D so.. whatever
Uncorking is now officially available for pre July 1st cars... which is why we are so excited.
They currently need the owners to bring their cars to a service center to do the upgrades, but maybe in the future it may be available OTA.
Are you sure it can be done over the air?It can be done on 100D and it can be done OTA. Performance benefit for 100D X/S isn't very much but it can still be done.
AFAIK if like the 75 uncorkingAre you sure it can be done over the air?
I called Tesla and they said it requires to be done at the SC.AFAIK if like the 75 uncorking
it can't be done OTA
I'll believe it better when it has a wider sampling of the S100D. One example that behaves differently from the spec is not something to hang my hat on.Go take a look at the Upgraded Performance Metrics thread, I have my 100D run logs in there. New DU00 100D's have the P1 configuration from factory (I have verified in the API), meaning uncorked. I have clocked 3.5-3.7s to 60, with about 430kW peak. That's 576 hp! All data and logs are documented, but we need more data from anyone with a new 100D.
Other 100Ds with VBOX's are clocking 3.7. Power output can't really differ when it's clear on the graphs, and I can tell you this is way faster than the 85D I had.I'll believe it better when it has a wider sampling of the S100D. One example that behaves differently from the spec is not something to hang my hat on.
It seems like it would be less of a hassle to just do it OTA.
That primary reason the rater range drops for P cars is the performance motor on the rear axle, which is bigger and less efficient but produces more power and more torque. It is an older generation motor too, as it never got a refresh. A corked or uncorked 75 still has the smaller, newer motor. Changing the perf curve may affect the EPA test somewhat, but not as much as a P.Considering the primary reason the epa drops the 90d Model X range from 300, down to 262.7 on the p90d - wouldn't it be logical that the 75D uncorking would require a different EPA value?
From ~238 miles down to ..... what - maybe 220 miles?
ok let's say that your assertion that it can be upgraded OTA is correct, the fact that they refuse to do it OTA effectively means that it won't get done OTA.Yes, it can be done OTA but their policy is not to. I can confirm it can be done OTA and without a firmware update. Go check the performance metrics thread I have before and after data there.
