Watts_Up
I agree, It should be connected to the 12 V auxillary to provide Qi fast charging.you guys are control freaks. i didn't see this useful.
The funny thing is that Jeda takes so long to ship that chances are by the time you receive it the knock offs will already be available.Jeda with its luxury tax for being first though the glass. I’ll wait for the knock offs.
vsSamsung SSD T5 Portable Specs: 500 GB $89.99 @best Buy
Operating 0°C to 60°C (140 degree)
Non-Operating -40°C to 85°C (185 degree)
vsSamsung USB 3.1 FLASH DRIVE Specs: 256 GB $50.99
Operating Temperature: 32 degree to 140 degree
Non-Operating Temperature: -50 degree to 158 degree
Samsung USB 3.1 Flash Drive Bar Plus 128GB $25.99
Operating Temperature: 32 to 140 degree
Non-operating Temperature: -10 to 70℃ (158 degree)
To Knightshade,
Where on the net did you get the idea that USB sticks have more tolerant of high ambient cabin temps than SSDs?
Samsung.com T5 manual said:Use the product in appropriate environment: temperature between 5°C - 35°C
Samsung.com Operating Temp range said:Operating Temperature 0~60℃
Where, specifically, do you keep getting lost in these facts directly provided from Samsung?
Thank you, Kognos.
Don't quote me on this, but USB flash drives are not built for this kind of use. They are made for occasional writing, not continuous or regular writes.
It depends on the type of flash memory and the controller. But it's true that there are few (if any) USB flash drives with high write endurance in the consumer market. But you can buy SD cards with high endurance and use them in the Tesla with a USB adapter.Don't quote me on this, but USB flash drives are not built for this kind of use. They are made for occasional writing, not continuous or regular writes.
I'm surprised they didn't do a couple of things.
1. Put TWO USB ports inside so you could plug in a sentry AND a music drive.
2. Add a power input so that if you could optionally run extra power to it and support high charging rates.
Then it might actually be worth the money they're charging.
That's what you get for thinking with your gut. The extra speed of the SSD is completely irrelevant to the application. The SSD draws too much power, is too big physically, and dealing with partitioning is a nuisance, at best. Also an SSD costs much more than two equivalent USB drives or SD cards.That's why I asked about the SSD volume and on a related thread I've started pushing the multiple volumes per drive, and trying to fix my issue of teslacam + music on one SSD. Because I can see a long-term vision idea where really you just manage a singular external storage device. If that really works, then devices like this thread is pushing are perfect and even more optimal ... thumb/flash drives aren't as fast as SSDs.
I just have a gut feeling that it's better to have faster writes and more space, and SSD is ultimately going to be more reliable in this context. And no real point in getting two USB thumb drives if you can get one faster unit that this particular hub works well with, yes?
It also answers a different problem - most devices are moving to USB-C and there are two available by this device.
If I can solve the single SSD problem I probably would get this Jeda hub.
Thank you, Kognos.
AND it advertises being "Built to be cool and durable."
- Dynamic Thermal Guard technology (helps maintain optimal performance and temperature)
- a heat sink (keeps surface temperature below 45°C*)
