Luudcrs
I'll wait for Taptes' $25 version.
My thoughts exactly! Just wait a couple months.
not talking about HEAT from inside a car. it's a USB drive heating up even after only a couple minutes of use.
a quick googling...
Non operating:
- 40 degree (Fahrenheit)
185 degree (Fahrenheit)
not sure what you mean by the drive doesn't know...
I said heat, I meant a USB flash drive that it would heat up even after only a couple minutes of use.
another googling...
Operating (I think it means when you're using the SSD)
140 degree Fahrenheit
Your manual said:Use the product in appropriate environment: temperature between 5°C - 35°C
a
if you call media files transferring (24 7) Light, you win!
Give it a few months and there will be knock offs for half the price. Cough Taptes cough.Price is 2X what I would pay. Can't fit a full size SSD. I'll pass. I do like how clean it is.
Your realize the drive is operating when the car is parked and sentry mode is on, right?
A fair point but anyone who's willing to use sentry would probably have COHP active as well especially in this context.
Leaving sentry on for longer than 12 hours in a hot condition would be a risky bet.
Yes, and you've pointed that out several times before. Generally what that spec means is that they no longer guarantee the device if you exceed those numbers. Practical experience has shown this ssd solution to be more reliable than any of the flash drives (all high quality ones) I've used previously. Of course my use case may not be typical for folks in the south - I have an air conditioned garage, and a relatively cool garage to park in at work. And if/when this ssd goes "out" you'll certainly hear about it from me here.FWIW specs on that drive also say
Operating temperature 32ºF to 95ºF (0ºC to 35ºC)
So slightly lower than the Samsung for cold temps, but same limit on the high end.
Obviously that spec doesn't mean it's gonna explode at 96 degrees, but I'd be less confident in that devices long term reliability sitting in a 100+ degree car routinely than a device whose operating temp range goes a lot higher (and specifically calls out in its features it's designed to handle high temp operation)
Still no problems with my SSD even when parked in the sun all day at work. I’ve not heard of anyone that had an SSD fail in their Tesla
