I needed to post that before @Tony_YYZ beat everyone to it
Have no idea what is included yet. I was on 44.1
Maybe...maybe it looks like the windows some down a tiny bit further than before. But I never really paid much attention before to how far so it may be the same. If it weren't for the release notes I probably wouldn't have noticed a difference.Any of you speedy research guru’s figure out exactly what the window position and charge connector behaviours actually mean ?
Immediately have an issue removing the charge cable. Get a message in the app saying cable isn’t installed properly. It’ll charge but won’t come out. No option in the car to unlock charge port. Just says ‘start charging’ App doesn’t give unlock option either
Apparently if there is nobody sitting in the car, the window goes all the way up and then comes down a bit?
Looks like it. A reddit user uploaded a video:
Model 3 44.2 software contains cold weather improvements! : teslamotors
Is it low enough that you would be able to open the door without it retracting at all?Obvious concern is whether or not water will get in with the window not forming a tight seal with the upper weather stripping. Seems like a crappy solution. When my windows froze, it wasn't the top of the window that was the issue, it was the bottom of the window frozen against the rubber strips where the glass retracts into the door. This new behaviour won't help with that.
