If a Tesla battery pack was subjected to freezing for a long enough time - would this damage the 2170 cells? Forget about range - I'm asking about irreversible cell damage.
But, the pack's temperature is regulated (i.e. protected) by the software using the energy stored in the pack; the pack won't freeze unless the car isn't plugged in and is left in freezing weather long enough to reduce the stored charge to near zero.
So is the final answer that there is no heating of the battery at all until we turn on either the climate (to get battery preconditioning) or actually start using the car/battery? That seems to be what I’ve seen from all these threads... which means that the battery can’t ‘freeze/damage’ itself from any normal weather we are likely to see.
Well... no heating unless the car feels it needs to keep the battery pack warmer than ambient temperature. Then the car automatically heats the battery whether the owner is there or not.
The other question is, what is actually doing the battery heating when we are running this preconditioning? Is it anything more that the climate heat or is there really heat in the battery coolant fluid warming it up? The reason for this line of thought are threads mentioning that the climate doesn’t turn off when reaching the set temperature.
I can't answer the true technical part (what is it ACTUALLY doing), but from everything I've seen, preconditioning uses energy (from battery, or wall if plugged in) to heat both the climate and the battery, so yes, the fluid is being actively warmed at those times. The climate doesn't turn off? Or the *fan* doesn't turn off? Climate control also reacts when the sun is shining brightly into the car (with a little, but only a little, heat) - by cooling. So I just manually adjust the temp ignoring, almost, the digital number, and what the fan is doing. This is especially noticeable on long trips -- after about 30 minutes of driving, the climate control seems to freeze our legs until we just increase the temp dial.
It is wasting energy to warm the car or battery in the middle of the night. Even one hour prior to leaving wastes some energy but the car will be nice and toasty and ready to regenerate.
Agree totally 10-15 minutes prior to leaving is enough to have the interior toasty, and will also do some battery heating.
The newness of this feechur is that turning on climate from App is also now invoking battery heater, if and when and how the car wants, it will sprinkle in battery heat along with your comfort heat. Using this feature without also having the charge cable plugged in is a sure way to reduce range rather than extend it.
My understanding is, the battery preheating always happened whenever the car's climate was turned on (e.g., via the app), but both would only run for 30 minutes then shut off. Same if driver is in the car; auto-shutoff after 30 minutes of not touching controls. The new feature merely stops the auto-shutoff, but everything else is the same.
