So the Tesla is fairly easy to take then, if P2D is not enabled?Turn on pin 2 drive and turn off passive entry
All this super amazing software on the car but can’t come up with anything to combat relays?
No fobs
Phone enabled as key
Phone nowhere near the front of the house
@EVMeister is correct. Although not impossible the TM3 is very hard to steal and the relay attacks that have been used in the UK to steal cars with keyless entry won't work.No fobs
So why not just say this to my original post?Why would that situation cause any issues? And why did you disagree with my post? Seems like you're overthinking things and have a basic misunderstanding of how relay attacks work. Hint: with the Model 3, they don't. They amplify RFID frequencies, they don't work in the same way against bluetooth signals.
That was his first reply to your post?So why not just say this to my original post?
Ok.....model 3, apologies I maybe should have pointed it out earlier.No offence, but maybe you have reading comprehension issues? I literally said: "The Model 3 "key" uses NFC (card) or bluetooth (phone), so traditional relay attacks don't work against them." You also didn't specify which Tesla you were referring to so it was appropriate for me to bring in the Model S and X which can unlock in a different way, just in case.
If I remember rightly the number of Incorrect pin entries on an iPhone is limited before a delay kicks in. I haven’t forgotten my pin for a while so could be wrong!If there's a lock, then there's a locksmith.
The FBI couldn't crack the 4 digit code to access the iPhone from the 2015 San Bernardino shooting.
FBI then paid a third party to successfully do that for them.
To be fair, they looked at it and walked by. Hopefully they think it’s too much of a chew to take.If I remember rightly the number of Incorrect pin entries on an iPhone is limited before a delay kicks in. I haven’t forgotten my pin for a while so could be wrong!
I presume there’s no such delay in the M3. If there were, that would likely make any little brats give up
Plus the “allow” buttonAlways PIN to drive. Why take the risk. Not much of an effort to key in 4 numbers.
